It is currently Wed Mar 21, 2018 4:35 pm
after dross removal.....
Brew Worx
Postby Brew Worx » Wed Sep 02, 2015 2:19 pm
So, after dross removal of a flavor of methods mention in other threads, I typically use the flapper wheel to do a clean up on dross side with a 60 grit. Typically i flip over to presentation side with 120grit for polishing. Allot of our stuff is acid etched.
I should mention i try to cut only CRS as the presentation face is always good for the surface etching fro Steel FX
This does make a sharp edge. Somewhat of a burr. Regardless, its sharp to the touch and I dont want customers to feel that its a problem. Or unfinished. Hobby lobby junk from china is nice a dull. Smooth rounded edge. So if I want to be as good or better i need a better process.
I have been using a wire wheel to dullen the edge.
Whats a few better ways to do this?
Brew Worx.
Blue Frog Metal Works
Arclight 4800 :D :D
Hypertherm 45
4 inch tube cutter
Mach 3, SheetCAM, Solid Edge 2D, Solid Works 3D, CREO, Inkscape, and a few cobb webs
