It is currently Tue Aug 21, 2018 3:50 pm
Cleaning/dross removal etc. Will this work?
gamble
Postby gamble » Mon Dec 22, 2014 4:18 pm
Anyone use one of these? Or know what they are called? I'd be looking for an electric one.
http://www.eastwood.com/eastwood-pneuma ... -tool.html
Wondering how well they work for removing dross and sanding down so the metal can be ready for patina
Torchmate 2x2 - Flashcut
Powermax 45 - Machine torch
Taig CNC Mill - Flashcut
Razorweld Distributor
AnotherDano
Re: Cleaning/dross removal etc. Will this work?
Postby AnotherDano » Mon Dec 22, 2014 4:45 pm
$300.00 will buy a lot of flap disks.
I use a belt sander, after removing any heavy dross with a quick swipe of a twisted knot cup.
The flap disks are prone to gouging and I try to avoid that as much as possible - especially on the 'front' of a piece.
Dano Roberts
[email protected]
PlasmaCam DHC-2 v3.11
Hypertherm PowerMax-30
gamble
Postby gamble » Mon Dec 22, 2014 5:07 pm
AnotherDano wrote:$300.00 will buy a lot of flap disks.
lol that's why I want an electric one. I burn through flap wheels pretty quick.
I HATE twisted knot cup. I don't think it works well at all. I even turned it sideways to get the meaty part of the knot to hit and it flings stainless strands everywhere. Had one sticking out of my hand. No thanks.
This is the one I tried
http://www.harborfreight.com/3-inch-twi ... 47927.html
CNCCAJUN
Postby CNCCAJUN » Mon Dec 22, 2014 6:41 pm
I can assure you that thing will throw also . . .maybe not as much, but will throw.
We used to have one similar to it in an industrial version they used to make welds pretty in a Budwieser plant in the process area in Bakersfield.
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
abmetal
Postby abmetal » Mon Dec 22, 2014 10:34 pm
Since I've started using the Norton Avos sanding discs, I use very few flap wheels. And the Avos discs last a long time.
Allen
HammerDownJustin
Postby HammerDownJustin » Sat Jan 10, 2015 3:36 am
Sell the Longevity and buy a hypertherm...that will help your dross the most. I started with a longevity also.
Miller 251 Mig
Redneck
Postby Redneck » Sat Jan 10, 2015 3:31 pm
[/quote]
http://www.harborfreight.com/3-inch-twi ... 47927.html[/quote]
The best wire wheels I've found are the ones I get from my local NAPA store.....I use the knotted ones and keep them pretty flat on the surface when using them. Takes 90% of the dross right off. They cost about $12 or so and last a good long time, with little wire loss.
I also have been happy with flap wheels made by Camel. I get them from ENCO. They are about $3 ea. if you buy a box of 10.
Just my 2?
Shane Warnick
Postby Shane Warnick » Sat Jan 10, 2015 11:41 pm
It should work, my concern would be longevity of the media and cost to replace. If you end up getting it run it for a month and let us know. Thx
Shane
mdwalker
Postby mdwalker » Sun Jan 11, 2015 1:00 pm
I use the twisted knot brushes on almost everything. I don't think you can find anything that will remove the dross faster, but they are dangerous. They will grab your shirt and whip your a$$ before you know what got you, lol. I have the scars to prove it. The main point I would like to make though is that if you have dross that a wire cup brush won't easily remove then you probably have other issues. I don't have experience with anything but Hypertherm but if you have your machine and table properly set up you should have very little dross and what you do have should be easy to remove. It is much more economical to take the time to set everything up properly and keep new or undamaged consumables in your machine than to spend time cleaning parts.
muzza
Postby muzza » Sun Jan 11, 2015 8:08 pm
mdwalker wrote:I use the twisted knot brushes on almost everything. I don't think you can find anything that will remove the dross faster, but they are dangerous. They will grab your shirt and whip your a$$ before you know what got you, lol. I have the scars to prove it. The main point I would like to make though is that if you have dross that a wire cup brush won't easily remove then you probably have other issues. I don't have experience with anything but Hypertherm but if you have your machine and table properly set up you should have very little dross and what you do have should be easy to remove. It is much more economical to take the time to set everything up properly and keep new or undamaged consumables in your machine than to spend time cleaning parts.
Agree 110% fix the cause and you don't have a problem, I cut a lot of 24" x 18" oval signs which take about 30 seconds each to do with the wire wheel on the grinder if they need doing at all.
I've wrecked a couple of shirts too :oops:
Murray
ZTFab
Postby ZTFab » Fri Jan 16, 2015 11:57 am
What do you expect from a Harbor Freight wire brush?
Stop buying crappy tools and being disappointed with the crappy results you get.
You have to look at the value of an item, not the price.
gamble
Postby gamble » Mon Jan 19, 2015 10:56 am
lol i don't know. I went with a cheap one because I figured it was so simple, stainless wire. didn't think it would of made a difference. Guess i was wrong.
see&see
Postby see&see » Mon Mar 09, 2015 12:11 pm
Norton Avos sanding discs are the way to go for light dross removal. On heavier material with slower cuts and more dross I use an air hammer with a wide flat blade first and Norton Avos sanding discs for the finishing touch..
abmetal wrote:Since I've started using the Norton Avos sanding discs, I use very few flap wheels. And the Avos discs last a long time.
Allen
PlasmaCam DHC2 4 x 4 & Sampson 510 Snap 'n Cut w/Safety Switch Interface Hypertherm 85 & 45XP
whiskeymike
Postby whiskeymike » Thu Sep 03, 2015 12:13 am
Fwiw, I've been picking up my abrasives at http://www.grindtoolabrasives.com and have been really happy. I've been getting 9" PSA green zirconia discs for my grizzly sander and they work fast and last about 3 times as long as my previous vendor. I ordered some flap discs and 3" Roloc stuff. I found the guy from Pirate.
littledigger
Postby littledigger » Wed Sep 30, 2015 8:36 am
I have been using a wire cup on a air powered buffer. Turns a lot slower and it's a lot safer !!
