It is currently Fri Jul 20, 2018 1:08 am
Paint on powder
sawdust1
Paint on powder
Postby sawdust1 » Fri May 11, 2018 9:26 pm
I am making a flat wall hanging of an airplane. I have powdered and cooked the base colour. I would like to mask and use spray paint for the details. Does it matter what kind of paint? The powder layer is plastic, should I use a plastic paint or rust paint or,,, I am open to suggestions. I intend to clear coat the final project.
little blue choo
Re: Paint on powder
Postby little blue choo » Fri May 11, 2018 9:45 pm
Use what ever paint you like. Have never had a reaction with paint and power. On the other hand you can get a bad reaction between different paints so do test if you're not sure.
Rick
Rick
Arclight 9600 4x8 table
sawdust1
Re: Paint on powder
Postby sawdust1 » Fri May 11, 2018 9:49 pm
Thank you Rick, I will mask progressive layers so they should not touch.
sawdust1
Re: Paint on powder
Postby sawdust1 » Sat May 12, 2018 12:15 pm
Looked excellent.... then I clear coated it...
Wash and retry.
little blue choo
Re: Paint on powder
Postby little blue choo » Mon May 14, 2018 11:50 pm
Like I said different paints react. If not sure do a test on a piece of scrap. A little time to test can save you a lot of do overs. Sorry
Rick
Rick
sawdust1
Re: Paint on powder
Postby sawdust1 » Tue May 15, 2018 12:10 pm
It's all learning and I am OK with that! I am having difficulty preventing bleed under the tape. I have the proper tape, I think I need to roller it down tight just before I hit the nozzle. When I use vinyl from my drag cutter I do not have this problem.
