Here is a Scotch brite wheel attachment I made for brushing SS and aluminum. I have used it a few times on large signs and it works great. The wheel is a floor "cut and polish" type in a "7A" grit, I would say it is a medium scotch brite or maybe a 600-800 grit. I moved the location of the drill motor to over the attachment to balance the load and use the cut oxy signal to start in using mach3
Aluminum and SS brushing attachment
Re: Aluminum and SS brushing attachment
I like it, thinking outside of the box you were!
David Finch CWI
Plenty of welders
Plasmacam 4x4 with DHC2
PowerMax 45
Lots of other toys
Plenty of welders
PowerMax 45
Lots of other toys
WSS,
Do you think this roll you are using would work as well on mild steel. I would like to do the same finish with straight lines running the length of the oart.
Gary
Gary
Candcnc DHCTII Electronics
Sheetcam, Mach 3
Corel Draw 8, V Carve Pro
Miller CTS 280 Miller Mig
Sheetcam, Mach 3
That looks very nice, where did you get the scotch brite roll? Thanks
- modelaratrod
I looked also for a scotchbrite floor sanding drum and didn't find one like that, Would you share your parts list?Garysbiz wrote:That looks very nice, where did you get the scotch brite roll? Thanks
5x10 Torchmate 2 w/AVHC
Hypertherm PM85 w/ machine & hand torch.
- 1fine79
Me too. I would love to find a roller/polishing wheel like that! please share a supplier and part # if possible.
Man I can just see my machine with that attachment....very cool!
Wayne
Torchmate 2 self-built 5x10 w/ SS water table AVHC New
Hypertherm PM65 New
Miller Spectrum 2050 hand torch
Miller Syncrowave 250 DX
Millermatic 212 w/ spoolgun
Lincoln SP-250
JD squared Model 32 hyd.bender
Hypertherm PM65 New
Lincoln SP-250
Thats bad-ass!
I want to buy a burnisher so bad. After I sort out this clear coat issue and get my booth built
here what I found but no price or dealer
http://solutions.3m.com/wps/portal/3M/e ... 715&rt=rud
This one was 37" wide
I was contacted by 3M sales today about my inquire for price and location of a wheel like shown in the start of this post.
OMG no way I could afford one like that, custom made more then the cost of a table and plasma.
However a 2" wide 8" diameter wheel to use on a bench grinder is less them $100.
