It is currently Fri Sep 21, 2018 8:12 am
Aluminum and SS brushing attachment
Learn and share abrasive & texturing finishing techniques, experiences, and product knowledge here.
WSS
Postby WSS » Thu Jul 25, 2013 12:02 am
Here is a Scotch brite wheel attachment I made for brushing SS and aluminum. I have used it a few times on large signs and it works great. The wheel is a floor "cut and polish" type in a "7A" grit, I would say it is a medium scotch brite or maybe a 600-800 grit. I moved the location of the drill motor to over the attachment to balance the load and use the cut oxy signal to start in using mach3
weldor2005
Re: Aluminum and SS brushing attachment
Postby weldor2005 » Thu Jul 25, 2013 5:38 am
I like it, thinking outside of the box you were!
David Finch CWI
Plenty of welders
Plasmacam 4x4 with DHC2
PowerMax 45
Lots of other toys
grindergary
Postby grindergary » Wed Aug 07, 2013 8:32 pm
WSS,
Do you think this roll you are using would work as well on mild steel. I would like to do the same finish with straight lines running the length of the oart.
Gary
Candcnc DHCTII Electronics
Sheetcam, Mach 3
Corel DrawX6, V Carve Pro
Miller CTS 280 Miller Mig
Garysbiz
Postby Garysbiz » Fri Aug 09, 2013 3:00 am
That looks very nice, where did you get the scotch brite roll? Thanks
modelaratrod
Postby modelaratrod » Wed Oct 02, 2013 1:13 pm
Garysbiz wrote:That looks very nice, where did you get the scotch brite roll? Thanks
I looked also for a scotchbrite floor sanding drum and didn't find one like that, Would you share your parts list?
5x10 Torchmate 2 w/AVHC
Hypertherm PM85 w/ machine & hand torch.
1fine79
Postby 1fine79 » Thu Jan 02, 2014 4:29 pm
Me too. I would love to find a roller/polishing wheel like that! please share a supplier and part # if possible.
Man I can just see my machine with that attachment....very cool!
Wayne
Torchmate 2 self-built 5x10 w/ SS water table AVHC New
Hypertherm PM65 New
Miller Spectrum 2050 hand torch
Miller Syncrowave 250 DX
Millermatic 212 w/ spoolgun
Lincoln SP-250
JD squared Model 32 hyd.bender
Cracker Red
Postby Cracker Red » Sun Aug 10, 2014 1:07 pm
Thats bad-ass!
I want to buy a burnisher so bad. After I sort out this clear coat issue and get my booth built
Postby acourtjester » Tue Aug 12, 2014 12:00 am
here what I found but no price or dealer
http://solutions.3m.com/wps/portal/3M/e ... 715&rt=rud
This one was 37" wide
Everlast PM 256 tig
Postby acourtjester » Tue Aug 12, 2014 2:46 pm
I was contacted by 3M sales today about my inquire for price and location of a wheel like shown in the start of this post.
OMG no way I could afford one like that, custom made more then the cost of a table and plasma.
However a 2" wide 8" diameter wheel to use on a bench grinder is less them $100.
Everlast PM 256 tig
Return to “Abrasive & Texturing”
