It is currently Mon Jun 18, 2018 1:34 pm
My Oven Build 4x4x6 (About)
LakeCruiser
Re: My Oven Build 4x4x6 (About)
Postby LakeCruiser » Tue Jan 10, 2017 10:31 am
OK. Holidays are OVER and it time to get this oven finished.
I got the small door mounted into the large door. I'm pleased with the way this turned out.
The only thing that bothers me is the oven door weighs a ton!
I got the big wiring done and all SSR's are running good and cool and she gets
hot quick.
Hope to get the big door on this week and the top fully insulated.
This thing is a BEAST!
Homemade 36X36 table
Can go from Plasma to Router in 10 Minutes
American Modified Chinese Controller
Proma Electronics THC
Cambam and Mach3
Longevity Forcecut 40D
Miller 211 MIG Welder
LakeCruiser
Postby LakeCruiser » Tue Jan 10, 2017 3:03 pm
acourtjester wrote:Look great did you use hi-temp insulated wire between the SSR and the elements??
I assume your timer is set to start when the oven reaches cure temps.
I like that idea acourtjester! I may incorporate that in the timer function.
Cambam and Mach3
Postby acourtjester » Tue Jan 10, 2017 4:27 pm
Great Idea to install a standard oven door for viewing instead of having to build one from scratch.
I scrounged a oven door for the glass viewing post and was surprised the glass sheets were separate parts of the door and not an assembly. Whoops :o :( Now it will take an extra effort to add them to an oven when I build a bigger one. :roll:
Everlast PM 256 tig
LakeCruiser
Postby LakeCruiser » Tue Jan 10, 2017 5:23 pm
I found a stainless steel door at our local appliance graveyard. It cleaned up nice but it is heavy.
I took it apart to just use the glass but by the time I built a frame I would not have gained anything.
The glass itself is very heavy.
Did you vent your oven anywhere?
Cambam and Mach3
LakeCruiser
Postby LakeCruiser » Tue Jan 24, 2017 2:03 pm
OK. She's a cookin'!
Inside is sealed!
Trolley build has started. I gotta get some more metal.
She takes about 30 minutes to get to 400 degrees.
Stands tall! almost too tall for my basement.
Cambam and Mach3
SONIC
Postby SONIC » Wed Jan 25, 2017 9:26 am
Awesome!
chattacuda
Postby chattacuda » Fri Mar 03, 2017 8:13 pm
I finally finished my oven too. Very similar design. 4' x 5' x 8'. Mine took 40 minutes to get to 400F, starting at 60F. I have the rack built. Started working on the sled for the rack today. Be glad to get to be able to actually use it. Maybe next week! Got any pics of your finished rack or rack sled?
chattacuda from Dayton, Tennessee
CandCNC electronics, Precision Plasma V rail gantry, homemade 4'x8' water table
Hyperthem 45, Sheetcam, mach3, Corel Draw
Postby acourtjester » Sat Mar 04, 2017 9:56 am
Nice work mine is horizontal and not as big but the sled works fine rolls on small steel wheels
Everlast PM 256 tig
Capstone
Postby Capstone » Sat Mar 04, 2017 12:13 pm
acourtjester wrote:Nice work mine is horizontal and not as big but the sled works fine rolls on small steel wheels
Jester, I'm very curious why, in this horizontal configuration, you would build it to have a rounded top?
Seems like a waste of available oven space and more difficult to build. Plus, you lose a good-sized surface to store crap when it's not in use :)
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
Postby acourtjester » Sat Mar 04, 2017 12:36 pm
You are absolutely correct with your thinking, But when I built it this fit my needs. I was powder coating longer thing then tall and I can move it around with the handles and wheel attached and store it vertical and place things on the top end. :lol: :D
The last things I powder coated fit just fine (rail road cart parts)
Everlast PM 256 tig
Return to “Powder Coat”
