ok my booth and oven are 95% done wiring left to do, i need to build some carts at least two but what type of wheels are there, obviously high heat ones, just wondering what type of wheels you guys have used and had good luck with.
thanks
john
oven cart
Re: oven cart
I just cut steel wheel out of 1/4" plate and put a bolt through them to mount. Your not taking about speed or distance so they worked great.
Re: oven cart
Here is what I am using. http://www.amazon.com/dp/B00THJKYGK/ref ... JXLU30AAEV. I saw a build somewhere where the builder tack welded two pieces on angle iron with the 90 degree angle up in the floor of his oven as guides for these wheels to run on which I copied. I am using hi temp nickel Nver-Seez as lubricant. Just a thought
chattacuda from Dayton, Tennessee
CandCNC electronics, Precision Plasma V rail gantry, homemade 4'x8' water table, Sharpe Air Dryer
Hyperthem 45XP, CommandCNC, Sheetcam, Corel Draw
Re: oven cart
Thanks for that info. I just got my 4 in for my build.chattacuda wrote:Here is what I am using. http://www.amazon.com/dp/B00THJKYGK/ref ... JXLU30AAEV. I saw a build somewhere where the builder tack welded two pieces on angle iron with the 90 degree angle up in the floor of his oven as guides for these wheels to run on which I copied. I am using hi temp nickel Nver-Seez as lubricant. Just a thought
Homemade 36X36 table
Can go from Plasma to Router in 10 Minutes
American Modified Chinese Controller
Proma Electronics THC
Cambam and Mach3
Longevity Forcecut 40D
Miller 211 MIG Welder
Cambam and Mach3
Re: oven cart
I ended up getting the high heat wheels from eBay and they suck, just switched to metal wheels and so much better
