It is currently Mon Jun 25, 2018 12:24 am
Suggestions on how to achieve this look
radnurse68
Postby radnurse68 » Wed Jun 10, 2015 4:33 pm
I need to recreate this technique /look on a much larger scale. It appears that they have braised brass onto the mild steel and sanded it down a bit. I'm open for suggestions on how to achieve this the easiest and cheapest way?
Stephen W. Sparks RN,CRN
Creating Sparks Metal Worx
Arclight Dynamics Arc Pro 12000 5X10
Linux, Sheetcam, Inkscape, Solid Edge
MIllermatic 175
AHP Alphatig 200X
Kool Koat 3.0 DPW
"Ridin around having a big time!"
radnurse68
Re: Suggestions on how to achieve this look
Postby radnurse68 » Wed Jun 10, 2015 5:13 pm
MIllermatic 175
AHP Alphatig 200X
Kool Koat 3.0 DPW
kb3gun
Postby kb3gun » Thu Jun 11, 2015 8:39 am
Looks like they brazed over it with a bronze rod.
-Smitty
Torchmate 4X4 Growth Series w/AVHC
Hypertherm PM45 w/ Machine Torch
Miller Syncrowave 210 TIG
Postby acourtjester » Thu Jun 11, 2015 11:36 am
You may contact the guy at "SteelFX" about his Copper F/X you may be able to used a eye dropper to spot the places you want copper color to be.
In place of the normal spray application :lol:
It will not have the texture of the blobs of copper but may do what you want.
Everlast PM 256 tig
Postby tnbndr » Fri Jun 12, 2015 8:29 am
He could achieve the blobs by just placing short welds randomly along the letters, then touch with a grinder to polish and then apply with dropper the copper FX. Should work, but time consuming.
PM45
Miller 211
RW 390E Slip Roll
yeomansjon
Postby yeomansjon » Wed Jul 15, 2015 8:11 am
What an awesome looking sign! Looks like he cut the letters and then hit it with a flap disk or something like it, then either top welded the pattern you see and hit with steel fx copper dye or braised with bronze. Then hit the tops with a flap disk.
Fast Jonny Custom Design
CNC Plasma Cutting
Plasmacam DHC
Hypertherm Powermax 1000
JimmyMac
Postby JimmyMac » Wed Jul 15, 2015 12:33 pm
It looks like the base metal is Stainless and they used a mig welder with regular steel and then hit it with Steel FX Copper after using a grinder.
Robert
Postby Robert » Sun Aug 23, 2015 6:55 pm
What type of font is that ?
Thank looks good
Shane Warnick
Postby Shane Warnick » Mon Aug 24, 2015 12:27 pm
I think your initial impression of brass rod brazed onto steel is correct. I played with this some, initially tried copper, but even with flux it would never stick to the steel. It would just wet out, and then roll off and drip and then fall off when it was cooled. Hard to tell from the picture if it's brass, or bronze rod. Tricky part is getting the flux where you want it, if you get carried away with the flux, and the piece is good and hot, then the flux will actually pull the metal you are brazing around with it, and can carry it where you may not want it. Of course, if the random look is what you are going for, no worries. Only other thing I can think of, is that the brass or bronze is a lot softer than the steel, so go easy with the sanding otherwise you might get to do it twice.
If you tackle it, post up some pics for us to see.
Shane
lobsterlift
Postby lobsterlift » Sat Aug 29, 2015 12:41 pm
hello, i have done this many times before. used more brazing rod and never sanded it, just cleaned with a wire brush and some tarnex (spelled wrong i'm sure) mine have alot more on them but it didn't start out that way. first pass looked much like what you want to do. i preheated the parts in the forge and used oxy/ acetylene to finish them off. flux covered ron with spoonfulls of flux added. most took 3 passes to get the coverage i have. i'll try and find a close up pic, but you can see spots of steel showing through if you look hard.
lobsterlift
Postby lobsterlift » Sat Aug 29, 2015 12:43 pm
having trouble loading pics
rons
Postby rons » Tue May 03, 2016 10:53 am
What is the name of the font
4x8 Home made with PPL Gantry
Bladder water table
Candcnc EtherCut + DTHCIV
Hypertherm PM 65 machine
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Ingersoll Rand 7.5 hp 80 gal
Harbor Ref. Dryer
reedjj
Postby reedjj » Wed Nov 01, 2017 10:38 am
TIG welding Silicon Bronze and buffing would work.
Return to “Patina Finishes”
