Since I'm not very good with creating files in CAD yet, I've been using Inkscape primarily to create my pre-cam vector files and saving them as .svg.
The method is to grab or create or alter a bitmap using a paint type program. Then Import that file into Inkscape. Trace the bitmap in inkscape. This works best when all the "metal" parts are black and all the "cutouts" are white when created in your paint program. The Inkscape trace function does a wonderful job of tracing bitmaps this way. Once traced in Inkscape There will be a trace vector file beneath the bitmap. Seperate them, delete the bitmap, and now your left with a .svg vector file.
That file can now be resized easily in Inkscape by setting the graph bars to inches, you can just pull on one corner to size it to any size you want. That size will now be the size of your part in Sheetcam. Save the file as a .svg. When done open Sheetcam and import the drawing into Sheetcam, setup your cut tools etc... Run your post and you now have a Mach ready .tap file , ready to cut on your machine.
This works very well if you more of a graphics background rather than CAD experience. It's especially good for artsy stuff where the exact dimensions are not critical.
Inkscape to trace bitmaps and export directly into Sheetcam
1 post
• Page 1 of 1
1 post
• Page 1 of 1
Jump to
- ↳ Introduce Yourself
- GENERAL FORUMS
- ↳ Plasma Cut Quality Forum
- ↳ Classified Ads
- PLASMA CUTTER FORUMS
- ↳ Hypertherm Plasma Cutters
- ↳ Powermax Cut Speed Charts
- ↳ 0-12 Fault Code
- ↳ 0-19 Fault Code
- ↳ 0-20 Fault Code
- ↳ 0-21 Fault Code
- ↳ 0-22 Fault Code
- ↳ 0-30 Fault Code
- ↳ 0-99 fault Code
- ↳ Plasma Consumables
- ↳ CandCNC Forum
- ↳ CandCNC Website
- ↳ FastCut CNC Forum
- ↳ FlashCut CNC Forum
- ↳ JD Squared Forum
- ↳ JD Squared Website
- ↳ Shop Sabre Forum
- ↳ Star-Lab CNC Forum
- ↳ Tracker CNC Forum
- ↳ Langmuir Crossfire Forum
- ↳ Torchmate Forum
- ↳ General Discussion
- ↳ BobCAD
- ↳ C&CNC CommandCNC
- ↳ Corel Draw Graphics Suite
- ↳ Inkscape
- ↳ Linux CNC - Plasmac
- ↳ Mach3 & Mach4 CNC
- ↳ Plasmacam - DesignEdge
- ↳ SheetCam
- ↳ Torchmate Software
- METAL FINISHING FORUMS
- ↳ Patina Finishes
- ↳ Paint & Other Top Coats
- ↳ Powder Coat
- ↳ Abrasive & Texturing
- ↳ Dross/Slag Removal
- ↳ Laser Engravers & Cutters
- ↳ Arclight Dynamics
