It is currently Fri Aug 17, 2018 3:07 am
Cutting a graphic into two parts
Searchman
Postby Searchman » Fri Dec 08, 2017 2:51 pm
I have a graphic that I want to cut in half so I can cut it on my plasma table. Then I can cut the two halves separatly and weld them together later. Simple way is nice for this guy
WyoGreen
Re: Cutting a graphic into two parts
Postby WyoGreen » Fri Dec 08, 2017 8:10 pm
So what program are you wanting to cut it in half with? CorelDraw, Inkscape, other? A little more information would be helpful.
CNC Router table
Gamelord
Postby Gamelord » Fri Dec 08, 2017 11:48 pm
You may be able to index your plate and cut it all out.
Searchman
Postby Searchman » Sun Dec 10, 2017 10:38 am
Using Inkscape
Old Iron
Postby Old Iron » Sun Dec 10, 2017 12:00 pm
Find a place on the drawing that works for a line to run across, use the divider tool separate the two halves draw a line from one point to the other on each piece then save them as two files.
Am I missing something here :?: :roll:
Return to “Inkscape”
