It is currently Thu Mar 22, 2018 12:00 am
Have a question and don't see your manufacturer? Post here and if we get enough action on that manufacturer we will add a forum
Postby BensPlasmaAu » Thu Oct 13, 2016 1:48 am
I was wondering if anyone knew anything about a Machmotion x15-250 controller. See photos below. Any good? What are they worth? Does anyone need on at the moment. I have found one at a very random location that is for sale. I'm still not sure if it is complete, but the control computer and cabinet is all there. Pretty sure there are no motors and not sure if the white control/power supply box is complete still.
Home built 3400 x 1400mm (11 and a bit X a bit over 4.5 feet)
Hypertherm Powermax 45
CandCNC Bladerunner IV
Some air dryer off the internet
Another water seperator I found unused on a shelf
Refrigerated air dryer
Re: Machmotion
Postby tcaudle » Sat Oct 15, 2016 3:49 pm
That may or may not have a parallel port interface to the PC (most likely it does) . The THC is either a THC300 (no presets ) or a later THC301D. Both are obsolete and you cannot get parts or support. It may have drivers internally and it will probably be steppers. They advertise life time tech support so they should be able to give you some help if you end up buying it.
