Hello everybody, something odd is happening. After I do my normal calibration procedures (preset volts) to obtain the appropriate volts for the cut. I start cutting completely normal but in a random moment the pwm sensor turns into test mode (the machine continues cutting but a bit higher than average). For the thc to act normal again I need to press the test button on the pwm sensor so it continues cutting (all this happens while the live job is in progress). Any ideas why this might be happening?
BladeRunner dragon cut DTCH II
Floating head
Powermax 65
4x8 table
Pwm sensor
Re: Pwm sensor
contact CandCNC tech support you may have a failure of the PWM unit
Re: Pwm sensor
Thank u for your support, the pwm sensor is new, I thought it was the problemacourtjester wrote:contact CandCNC tech support you may have a failure of the PWM unit
