Finally Cleaned out the Water Tray
- tnbndr
Well, a little over a year of cutting and with the water tray filling up I decided to tear out the slats and clean her out. Took about 4 hours of scraping and scooping. Result was 4 - 5 gallon buckets of metal dust that had accumulated and built up in the tray. The slats were not in bad shape but I turned them all over to start fresh. I also changed out the swirl ring and shield even though they still looked good I figured one year of use was good.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
Re: Finally Cleaned out the Water Tray
I lined my water table it ceramic tile (18" X 18" slick finish) and the gunk comes off in large chunks when its dry.
- Capstone
Jester, is that a watertable?
Cleaning out my relatively small 48x30 table was a royal pain. I can tell its time when the sparks seem to bounce off the surface of the water; or maybe that's just because I use straight water.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
does it help having the pan powdercoated vs galvanized ?
It be a water table with tap water when its full. I did use washing soda when I was going to leave the water in for long time but mostly I fill it cut and drain after a few days. I have the water table and slates painted with tractor supply paint
