It is currently Sun Sep 23, 2018 10:29 am
Wright cnc 5 x 10
Have a question and don't see your manufacturer? Post here and if we get enough action on that manufacturer we will add a forum
Rtodahl01
Wright cnc 5 x 10
Postby Rtodahl01 » Sat Nov 18, 2017 11:39 pm
Well, I bought a wright cnc 5 x 10 table.
I haven't seen much written on them.
I have seen some less than favorable comments on the web after I bought it.
I got it two weeks after having a total knee replacement
So it is slow going on the assembly.
Strictly me though because it is pretty easy to put together.
I use turbo cad for drawing. Then to sheetcam for g code and setup tommorrow I will replace my filter system on my air compressor and give it a go.
I have done a couple test runs without the torch running.
Glad I did.
Easy to miss inputting correct information.
Again, me learning the software.
Being one of the least expensive machines I anticipated needing to work out bugs.
So far it has been learning the software.
After I make some cuts I will post more.
MPN Signs
Re: Wright cnc 5 x 10
Postby MPN Signs » Mon Nov 20, 2017 2:08 am
I'm interested in your progress on the table. Please keep the updates coming. Good luck with the knee.
Old Iron
Postby Old Iron » Mon Nov 20, 2017 8:39 am
I also have an inexpensive table. The programming was the hardest part for me until I joined Plasmaspider.
The help that the members give is what turned the lights on for me.
Learn to read what the Sheetcam results are showing you and your life will be greatly reduced of stress.
Rtodahl01
Postby Rtodahl01 » Tue Nov 21, 2017 1:01 am
so today I put new filters in my air supply just to start fresh.
drew up a simple base plate and ran it
To my amazement it worked!
will hook up my THC tomorrow.
I like to do one thing at a time then I have less to troubleshoot if things don't work.
First cut was pretty clean.
Had some movement but I think it could be from torch height may be a bit high and the material was pretty small and moved from the airflow.
Rtodahl01
Postby Rtodahl01 » Sat Nov 25, 2017 5:09 pm
Ok, so far I am having good performance using drawings I make on Turbo Cad.
Love drawing up a part and seeing the machine cut it out.
Need to learn how to take an image from the net and make a DXF file.
I keep getting errors. And strange cut paths
thinwater
Postby thinwater » Sun Nov 26, 2017 11:20 am
Down load some dxf files that are "Known good" from plasma spider then try and see how they work. This way you will eliminate that part of potential user error. I am looking at one of these machines myself since my 4x4 plasmacam is to small for some of what I want to make.
I convert a lot of web images using Bobart. I put points all around the edges of the image I want, then connect them with either lines if they are straight, or arcs if they are curves. Once done I save what I drew as a dxf and just use that clean dxf for my path.
Rtodahl01
Postby Rtodahl01 » Mon Nov 27, 2017 11:13 am
I will try this.
Spending way to much time cleaning up expiramental images.
As far as the table goes it is working well
Rtodahl01
Postby Rtodahl01 » Mon Nov 27, 2017 11:16 am
Hope my picture comes through
destroyer000
Postby destroyer000 » Thu Nov 30, 2017 1:54 pm
i ordered a 4x4 a few weeks ago, i was in the same boat and did a ton of research, ldr was in my backyard and a few guys in my area have them. i came across a wright cnc table and it look decent. i reached out to them any they quickly responded. over the past few week i had no problem getting my questions answered from them even tho i didnt purchase anything from them yet.. thats great customer service! i like to give the small guy some business as well. i receive mine monday, i will also give some feedback
Rtodahl01
Postby Rtodahl01 » Thu Nov 30, 2017 11:27 pm
Awesome, Mine was about three weeks late.
So far been working well.
Issues today are that I have been playing around the settings and need to figure how to get back to default settings.
The picture above is a security box for rotating Christmas lights.
Loved drawing it up then cutting it out and everything fit perfect.
Rtodahl01
Postby Rtodahl01 » Sun Dec 03, 2017 11:36 pm
] couple of practice peices
Rtodahl01
Postby Rtodahl01 » Fri Dec 08, 2017 10:41 pm
:) set up thc.
Torch rose about an inch above the table while cutting.
Hmm,
Rtodahl01
Postby Rtodahl01 » Fri Dec 08, 2017 10:42 pm
Todays progress.
Finally put on the proma thc.
Hmm, going to have to go back to the set up.
Everything works great then the torch rose about an inch above the table. Strange thing is it kept cutting.
Rtodahl01
Postby Rtodahl01 » Mon Dec 11, 2017 8:35 pm
Power source died.
Talked to James Their tech guy.
Gave me information to ship back.
No problem, they are fixing and sending back.
Good response time and diagnosis.
Rtodahl01
Postby Rtodahl01 » Sat Dec 16, 2017 12:49 am
Power source fixed and being shipped back.
destroyer000
Postby destroyer000 » Wed Dec 20, 2017 11:44 am
ive been using mine last few days and so far no issues! james, walked me through a few questions i had but again was user error, i made a few battery trays, some new mounts for the truck iam building, so far great cuts an machine works fantastic! i just got done bending up the water pan so i will be cutting some grates tonight for that
Bollinger660
Postby Bollinger660 » Fri Dec 22, 2017 9:36 pm
I just ordered mine on Monday. Only got the 4x4 with water pan torch height control and new hypertherm xp45 with machine torch. Telling me about 7 weeks for delivery. I was going to build my own but don't have a lot of time so went this route. I have a powder coat and laser engraving business so that takes most of my time. James answered my questions very quickly. So far nothing bad to say about wright cnc.
Rtodahl01
Postby Rtodahl01 » Tue Dec 26, 2017 11:32 pm
so far I can't complain.
Glad you guys are having good luck also.
Bollinger600 did you get the package deal they offer?
I have the old version hypertherm 45 great plasma cutter
Bollinger660
Postby Bollinger660 » Sat Jan 06, 2018 3:05 pm
I purchased everything from them ,but to my know ledge there wasnt a package deal. I can wait counting down the days.
Rtodahl01
Postby Rtodahl01 » Sun Jan 28, 2018 2:47 am
Bollinger660 did you get your table yet?
Bollinger660
Postby Bollinger660 » Sun Apr 08, 2018 7:59 am
Got my table and i have been using it for couple weeks now. There is a bit of a learning curve coming from my laser engraved but getting there slowly. I had some issues with the brand new hypertherm 45xp that took some time to figure out but all in all it doing what it is intended for . Just like anything else sure wish i could have gotten a bigger table and bigger plasma cutter .
Haasfabrication
Postby Haasfabrication » Sun Apr 08, 2018 7:06 pm
I own a 4x8 and I've had it for about three months now I really like the machine and Wrights customer service is great! My only issue I have with the machine is my water table, the pan and slots are all 16ga material, and the pan comes in 4 pieces with about 20-25 bolts and nuts to connect the seams, you have to use silicone to seal it which for me hasn't lasted long. I'm currently overseas for work right now so when I get back I think I might make my own pan and slots for it out of one solid piece as well as a little thicker material.
destroyer000
Postby destroyer000 » Mon Apr 09, 2018 8:43 am
Haasfabrication wrote:I own a 4x8 and I've had it for about three months now I really like the machine and Wrights customer service is great! My only issue I have with the machine is my water table, the pan and slots are all 16ga material, and the pan comes in 4 pieces with about 20-25 bolts and nuts to connect the seams, you have to use silicone to seal it which for me hasn't lasted long. I'm currently overseas for work right now so when I get back I think I might make my own pan and slots for it out of one solid piece as well as a little thicker material.
i used some polyurethane sikaflex between my joints been together now for 4 months and no leaks.
ScottLister
Postby ScottLister » Thu Apr 12, 2018 7:08 am
I purchased a 4x8 unit from wright cnc in late feb. early march. They were great in helping me decide which one to get. Returned my phone call in less than 5 mins. Once they received my money they wont return my phone calls or answer my emails. Still haven't gotten a delivery date. Really hoping this isn't the norm with them.
Scott
ScottLister
Postby ScottLister » Tue Apr 17, 2018 6:57 am
Well I got an email from Wright cnc and my table has been shipped and should be here by the end of the week. I am looking forward to the assembly and testing process.
Scott
