by Bigrhamr » Thu Mar 10, 2011 10:33 am
TLJC,
Mine is a 5'x10' with water table. I have a Powermax 45 on it now which I can't say enough good things about. I also have a 1650 that is ready to go if/when I ever need it for heavier stuff.
The software up grades are through Dynatorch. The current version is 3.6.0.something. If you get on their website and look under "what's new" and go back in time to the version you have then read all the updates since then it will fill you in on that and probably point out a lot of things you didn't know about the capabilities. I have the Wecim/Cutting shop for nesting and drawing. If you don't want to shell out the money for Wecim there's nothing wrong with SheetCam. Mine came with a very old version of One CNC which I worked with for a few days before deciding it wasn't worth messing with.
Problems: Check, Locktite when appropriate and tighten anything that isn't supposed to move but can. Start with the couplers between the motors and gearboxes, then every setscrew on the pulleys and the bearing flange bolts. On mine the Z axis developed a lot of backlash a few times, I don't remember the details but it's pretty simple to take the bottom half apart and remove the slack. Also check the V rollers on the Z, one side has a cam in it to remove play.When I got mine the tuning numbers were way out of whack and it was cutting terrible parts and throwing lot's of errors. The book settings were actually worse. With some help from Leon and a lot of experimentation I got that straightened out.
The heavy construction is great, hit it with a forklift or drop a heavy piece of plate on it and it won't hurt anything.
Driving the gantry off one end for loading and having no rails or parts above the table is a plus, as is having all the
motion parts for X contained inside the frame. I can run it fast, 230 IPM for 16 gauge with good results. The only nagging problem now is a very small amount of backlash on X which seems to be from the belts and I'm working on that.
Now a couple of qualifiers on what I have written. I am asuming you have the same setup since it is the same model of table. And secondly on the support from Dynatorch they support their electronics no matter who's table they are on but not the mechanical parts if they didn't build it.
