This was the first real job with our plasma cutter, this job consists of 65 of these plates and 44 of half of the design on an 4x4x3/8" plate
TRACKER Nitro Plasma Cutter
Thermal Dynamics A120 Cutmaster
80A @ 42ipm
Finish:
Hot dipped Galvanized
One coat of Macropoxy 646 - http://www.paintdocs.com/webmsds/webPDF.jsp?SITEID=STORECAT&doctype=PDS&lang=E&prodno=B58W610
Two coats of Hi-Solids Polyurethane -http://www.paintdocs.com/webmsds/webPDF.jsp?SITEID=STORECAT&doctype=PDS&lang=E&prodno=B65W311
3/8" plate 4'x8' plate
1 down, 64 plates to go.
Special thanks to Justin and the team at Tracker, this is our first plasma cutter table, Justin answered over 60 questions by email and phone conversations, he always said, once you get the table ready at the shop, you will be ready to cut within an hour, he was right. The job went smooth with pause for a couple adjustments, one electrode was used on this plate. Looks like it takes about 75 minutes per plate, I will try with more power, but we are so happy with the quality at 80 amps that we mite just leave it alone.
