It is currently Mon Jun 18, 2018 9:34 am
Acelleration rates
Tracker Hardware discussion forum
saltydog
Acelleration rates
Postby saltydog » Sun Apr 12, 2015 11:21 am
How do you adjust acceleration rates on Tracker CNC, using Hypertherm 65 and having issues with finer detailed work and corners.
hacnwac
Re: Acelleration rates
Postby hacnwac » Sun Apr 12, 2015 9:03 pm
rates are changed in the settings when you open a file in the command and cut. Open a command and cut file click on settings (pierce time /delay/pierce height etc) there should be a box for acceleration amount in it that can be changed.
Mark
saltydog
Postby saltydog » Mon Apr 13, 2015 3:41 pm
I wish it was that easy..... apparently you have to hold the CTRL button and tap the "W" 6 times to unlock a hidden page. Going to try it tonight
hacnwac
Postby hacnwac » Mon Apr 13, 2015 10:53 pm
Sorry for the misinformation. I have an older tracker and that works for mine. I will have to try that w key on mine and see what happens
Team Tracker
Postby Team Tracker » Sun Apr 19, 2015 1:19 pm
saltydog wrote:I wish it was that easy..... apparently you have to hold the CTRL button and tap the "W" 6 times to unlock a hidden page. Going to try it tonight
It is still just as easy as before, the only difference is that the setting is hidden from most users. Many users have a tendency to alter the base settings without a full understanding of what they do and this can cause problems for themselves. Hiding this setting ensures they contact us so we can assist them and be sure everything is done correctly.
1-800-590-7804
Return to “Tracker CNC”
