Hi there new to this
purchased a TM 3 second hand 2 years ago and only just got time to set it up
the machine came with a cutmaster 151 and sl100
does anyone know if i can use the 9-8206 drag tip with this or has my suplyer sent wrong tip
any help appreceated
cheers fergy
TD 30 A tip TorchMate 3 - Cutmaster 151 and sl100
- Diverdude
Re: TD 30 A tip
you should be able to. I'm running a TD 52 on a plasmaroute table and I use 30 amp drag tip for cutting thinner steel with it and it does great, thinner kerf than the 40 amp tip.
PlasmaRoute HD 4x4
