dry run?
Re: dry run?
Sure. Obviously you won't be able to test things like a torch height control but if you're just wanting to check X and Y axis motions, you're good to go.
- tentonjj
Re: dry run?
great........thanx a lotredneckgateart wrote:Sure. Obviously you won't be able to test things like a torch height control but if you're just wanting to check X and Y axis motions, you're good to go.
Jayson Johnson
JMJ Graphix
920-517-7122
JMJ Graphix
920-517-7122
Re: dry run?
Just be careful when firing it up for the first time. Just because the torch isn't installed doesn't mean that you still can't do something dumb! LOL! Make sure all of your limit switches work and start off with slow, short moves. The last thing you want to see is your shiny, new, 4 ft. long table trying to do a 200 ipm move to the 5 ft. mark! Good Luck
- tentonjj
Re: dry run?
ok.......thanx for the tip!! lolredneckgateart wrote:Just be careful when firing it up for the first time. Just because the torch isn't installed doesn't mean that you can't do something dumb! LOL! Make sure all of your limit switches work and start off with slow, short moves. The last thing you want to see is your shiny, new, 4 ft. long table trying to do a 200 ipm move to the 5 ft. mark! Good Luck
Jayson Johnson
JMJ Graphix
920-517-7122
JMJ Graphix
920-517-7122
Re: dry run?
If you want to see some results, you could always rig up a Sharpie to your Z-axis. Put a piece of plate or MDF on the table, tape a piece of paper to it and run a test program. You won't be cutting steel but you'll wind up with a cool drawing!
- tentonjj
Re: dry run?
im not that fast...................i figure hot to run mach 3 yet. i so adjusyted to torchmate crap its hard for me to get stuff going
Jayson Johnson
JMJ Graphix
920-517-7122
JMJ Graphix
920-517-7122
