It is currently Sun Jun 24, 2018 8:38 pm
Plasma converting to router
Tipp_BB
Postby Tipp_BB » Thu Oct 19, 2017 9:32 am
When I bought my table I purchased the wood router option. I have not been successfully in figuring out a way to secure the wood to the water table. Does anyone out there have or know of a way to secure the wood to the water table. Do I need to put down some sort base with a clamping system to hold the wood down secure. If so do you or can you share how you are successfully in doing this.
tylerd
Re: Plasma converting to router
Postby tylerd » Thu Oct 19, 2017 11:20 am
Curious, what table did you buy? Can they provide some support?
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
C&CNC Bladerunner Servo
DTHC IV Feather Touch
HyT-Connect DCP-01
Sheetcam Inkscape QCAD
Postby tcaudle » Fri Oct 20, 2017 12:38 pm
You need to design a flat cutting surface with spoil board that covers your water table and have some way to level it if you want to do any cutting that needs controlled depth. You will need to keep the water tray covered unless you want routing debris floating in your tray. Years ago I built a combo router/plasma table and designed slide in trays for water (with drains) and an adjustable frame with MDF spoil board. It took about 45 minutes to change over from one to the other. While its neat for a hobbyist, proto shop or casual user to be able to do routing or plasma its not a great idea for a production shop unless floor space is missing. Separate tables have distinct advantages. Plasma assumes the material is not flat and all cuts are through and through. The THC will adjust for material not flat A router cuts dwon into the media and the depth is based on the material being flat and level. Being off a 1/4" out of level on a plams is not big deal (unless you have no THC) but it is on a router.
Router media needs to be secured to the spoil board and the spoil board needs to not move.
tylerd
Postby tylerd » Sat Oct 28, 2017 4:21 am
Yeah 2 tables or downdraft I would think would be the way to go
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
Return to “Torchmate”
