It is currently Mon Sep 24, 2018 9:28 pm
New growth 2x4 table issues,....need help !
poppopsworkshop
Postby poppopsworkshop » Sat Nov 07, 2015 5:10 pm
Having issues cutting on my new growth water table. Using accumove 2 controller and hypertherm65. When in dry run mode it travels fine. But in active run, it just pierces a hole and shuts down after 5 seconds or so. I'm also not sure I have my hypertherm65 set up correctly. any help is greatly appricated. Trying to cut 16 gauge.
madracing007
Re: New growth 2x4 table issues,....need help !
Postby madracing007 » Thu Dec 31, 2015 1:55 pm
do you have the raw arc voltage wire hooked up? along with the ok to move? sometimes when i forget to hook my ground to the metal it will do that maybe your not getting a good ground? in dry mode it dont look for those signals so it will just run
poppopsworkshop
Postby poppopsworkshop » Mon Mar 21, 2016 1:09 pm
Thanks, It was a bad ground in my electrical panel.
Return to “Torchmate”
