PlasmaCam Cutting Files
chris111391
Post by chris111391 »
i need files that are comptable for the plasmaCam plasma cutter. or i need to know how to convert the files from DHX form
wacco454
Re: plasmaCam
Post by wacco454 »
Do you mean dxf becouse I have a plasmacam to. All you have to do is import the dxf file and clean it up and chamg it to cut paths, that would now be a pcm file. then it is ready to cut.
metalmanart
Re: plasmaCam
Post by metalmanart »
Hi I have a plasma cam and sure would like to have someone creat a teaching dvd of all aspects of the operation of the plasma cam system coordinates,drawings,indexing large designs....any takers
Perry
jcfreer
Re: plasmaCam
Post by jcfreer »
I'm a plasma cam dhc2 it is fairly easy to use I have not tried to index anything but if it is as easy as the other stuff its not to tough. let me know if I can help. I will try to talk you throught the problem
FreeDXF.com
Re: plasmaCam
Post by FreeDXF.com »
I have DXF files that can be imported into your plasmacam and they can be viewed at http://www.customdxffiles.com
Jason
