It is currently Tue Sep 18, 2018 4:01 pm
Water table question
ironhorse
Postby ironhorse » Fri Jul 06, 2018 3:40 pm
Hi all, Hope July 4th was amazing for all of you in the Beautiful USA. I took the day off here and had me a few ones in celebration. Hey, I was wondering if any of you guys/gals out there in plasmacam land have ever converted your table to a water table? Possibly a silly question but I wont say I'm brilliant lol.
Greg
tcaudle
Re: Water table question
Postby tcaudle » Sat Jul 07, 2018 1:59 pm
Water tables and ohmic sensing do not play well together. Unless it mount the water tray far enough down to avoid purge air from blowing spray up you will get false touch off . Of course ifs its far enough down to avoid the spray it will be less effective on killing the plasma dust. Down draft desings work better
SeanP
Postby SeanP » Sun Jul 08, 2018 2:40 pm
I'm using water with your feathertouch Tom and to be fair it does very well really, just the first touch off you have to watch for puddles after that pre flow air does fine to clear it, I get more problems from bits of crud on the shield than water especially with fine cuts, it's great having the switch to go back to switch touch off on some materials though.
Powermax 45 with Duramax torch.
R-Tech 210 Tig, Jasic 250 mig
Sheetcam, Scanything, Coreldraw X8, Solidworks
Table build gallery
islander261
Postby islander261 » Sun Jul 08, 2018 6:27 pm
I use ohmic sensing (used to use a Feather Touch). ++ to what Sean says.
John
tcaudle
Postby tcaudle » Mon Jul 09, 2018 10:57 am
It (ohmic sensing) works better if you have a switch backup that will either perform a mechanical touch off in the event of the ohmic missing or e-stops the table. Ohmic will false and it will miss at times. PCAM tables use torque sensing on the lifter motor to sense if the ohmic is misssed. Not usre if it just faults or uses an offset ant keeps cutting.
hondafreak08
Postby hondafreak08 » Sat Sep 01, 2018 4:56 pm
i just started my build. ( still drawing it)
in essence, i will be using a modified grate design. tray will be shaped and sit very similar to the factory grates, then have a peice of stainless across gthe bottom to make the tray
as far as slats go, they will be shortened factory location slats that fit in the box
Return to “PlasmaCam”
