Preventative Maintenance Schedule
Is there a checklist I can look at for daily, weekly, monthly,and yearly maintenance? I am wanting to make my new machine operate the best possible for the longest possible. Any help would be appreciated.
Re: Preventative Maintenance Schedule
Grind the paint off all surfaces that the bearings ride on as it will come off and cause problems with cutting. Blow out the bearings and Z axis screw with an air gun once a year and spray with Mystery oil (turn them and wipe off excess). Remove the Z and X axis carriage and do the same to all bearings on it. Blow out the racks also. I have used my machine for over 15 years with no problems. I have cut quite a bit and haven't had to replace the bearings.
Dave Hanks
Dave Hanks
Is there anything you do daily before beginning to cut for the day?
Is there a weekly maintenance need?
Thank you for the pointers
Before each use of my machine I sand the tip and electrode with 180 grit sandpaper in my lathe. A drill press would work just as well.
Dave Hanks
Dave Hanks
