I have had my DHC for a few years now and all a sudden I'm can not control the piercing time, everything else works fine. Any ideas on what it could be?
Josh
DHC piercing problem....Please help.
Re: DHC piercing problem....Please help.
Are you running the upgraded designedge software?
If you, are there is a section in your settings, under the machine control tab that allows you to customize the pierce time: Try adjusting the value (that is highlighted in the picture) up or down to see if it makes a difference.
If you are running the old school software (version 3.11), your settings menu will have less features to play with than mine (designedge), but if I remember correctly, even back in the old software you still adjust the piece time in the settings in a similar way to what I'm showing you. Another thing you might want to check within the same section is if the "wait for signal before moving" box is checked. I usually have this checked. If your is not checked, check it. If it is already checked, uncheck it and see if it helps.
Give plasmacams tech people a call if its still not doing what you need to do a soon as you can. They'll get you up and going in no time.
Good Luck Brother
Good Luck Brother
