Set the plasmacam table up on level floor both directions read between the bubble, the 4 corners read 100% square.
Hooked up the tables computer but NOT the main computer and I ran a test on it. I hear the trip on the motor and
the switch as well but it does not move in test mode. it just sits there. Do I need the computer hooked up? Also
the parts seem a little tough to move manually. Everything is hooked up correctly but it still does not move. I cannot
imagine that I need the computer hooked up. If so I have to wait til monday as he did not give me his password to
get onto the computer.
Beginning to feel comfort in the fact that I wrote him a check and there is no way it will clear before Monday.
Put in test mode and it will not move
- rdj357
Re: Put in test mode and it will not move
Yes you must hook up the computer and initialize the machine for anything to work.
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
Thanks I did that and now everything seems to work. How do I learn the software? Is the info on the software in the manual? If so great I should have that on Tuesday
- rdj357
Yessir, that's Chapter 6.
Robert Johnson
Plasmacam has a really great owners community that is a fantastic resource for all plasmacam owners ( https://owners-community.com/) Their tech team also really great to work with if you ever need to talk some on in person.
Good Luck, Brother!
JAG
Good Luck, Brother!
JAG
