When I open an image from a disc, it looks fine. I convert it to cut path and all of these little wiggly circles appear in a lot of locations around the perimiter. Needless to say, the torch goes crazy trying to cut all this crap @ 135 ipm. Can someone tell me how to clean this up for a smooth cut ?
Jeff M
converting to cut path problem
- Craig
Re: converting to cut path problem
Jeff,
If you have the Advanced version of Design Edge then simply check the box for ?Exclude Crossovers? on the ?offset/ Convert? tab of the ?Settings? window. If you have the standard version then you will have to clean up by hand.
Craig Johnson
Craig Johnson
Craig Johnson
In the past I have scaled the drawing larger, converted it, then scaled it back down. Any method you use has its advantages and disadvantages.
- geo4932
Jeff,
If you are using the Plasmacam art disc you can open the image that already has the cut paths and use it as is.
If you want to apply tour own cut paths and you do not have the "Exclude Crossovers" feature, you can apply a Smooth to the drawing before converting to cut path. Highlight the drawing a and then select EDIT-SMOOTH. Type in .002 and hit ENTER. Also use a smaller kerf offset.
George
George
