It is currently Wed Sep 19, 2018 4:54 pm
HELP! Production ALL Stop until solution! Jesus, Jim Colt, Somebody!
ssmtyper
Postby ssmtyper » Sun Jan 14, 2018 6:04 pm
I have a roughly 6 month old PM45XP. It started this deal where sometimes it goes into a fault with the lights; Powr supply/Air/Ac all on solid.... I rechecked/changed consumables. Checked Air PSI 100 times. swapped to a different compressor with a different APR to be sure... Swapped to the Hand torch and still the same... With the hand torch I made a Video to show what its doing... The 45is fluttering the air psi, best I can describe... Watch the vid... https://youtu.be/ghqSgtDO_RU
urbnsr
Re: HELP! Production ALL Stop until solution! Jesus, Jim Colt, Somebody!
Postby urbnsr » Sun Jan 14, 2018 6:22 pm
Is it possible that there is something restricting the air flow? Teflon thread sealing tape drawn in, possibly?
Paul
ssmtyper
Postby ssmtyper » Sun Jan 14, 2018 6:54 pm
Hmm. I pulled the case cover. And don't see anything through the clear air lines... AND oddly enough it works perfectly sometimes still. For example. Just after I posted this I cut two different items flawlessly (roughly 30 min total cut time)...
Metriccar
Postby Metriccar » Sun Jan 14, 2018 10:20 pm
It sounds to me like it's something internal, but wanted to be sure... you have a pressure gauge at the back of the machine right?
ssmtyper
Postby ssmtyper » Mon Jan 15, 2018 5:28 am
I have tested with two different air compressors with different air regulators and different hoses... Though in both have gauges at tank side area... It's odd because it sounds as though something inside the cutter housing is trying to back the air off but it flutters to the point that during a cut the unit reads as low psi or something... And then farting with it a bit it will cut fine for a while again with no fluttering and no fault stops...
ssmtyper
Postby ssmtyper » Mon Jan 15, 2018 5:33 am
I notice in my vid I say "power supply, air supply, and a/c lights" the one I called power supply I'm thinking the book calls something to do with electrode... But I've chased that idea down also to no avail
Postby jimcolt » Mon Jan 15, 2018 10:24 am
As always....technical service is the best choice, the email and phone numbers are listed near the front of your operators manual. [email protected] or 1 800 643 9878 .
My first thought is to install an air pressure gauge hard plumbed at the inlet to the system. Read the gauge at static pressure, then activate air flow at the torch....read the same gauge again. You will see the pressure drop when you activate the torch....if it drops too low then that indicates some sort of air line restriction. Often the internal electronic air regulator will flutter if it is not being supplied adequate pressure. Could be an air hose with a small ID, air hose too long, too many filters, valves, fittings, plugged or frozen filters, etc. Jim Colt Hypertherm
ssmtyper
Postby ssmtyper » Mon Jan 15, 2018 1:21 pm
10-4. Thank you Sir... I will take these steps.
ssmtyper
Postby ssmtyper » Wed Jan 31, 2018 7:35 pm
UPDATE! it was the Solenoid pack, Hypertherm was a great help! All fixed up!
Users browsing this forum: No registered users and 4 guests
