It is currently Tue Jun 19, 2018 9:45 pm
t123 torch problem, burnt wires
i_r_machinist
Postby i_r_machinist » Mon Nov 20, 2017 8:39 am
I upgraded my table to a 85 amp machine with the duramax mechanical cutter a while ago and kept my ht 600 to cut my drop off up with. This has been working just fine until I saw smoke comming out of the handle of the t123. I took it apart and found this.
Where do the two red wires attach? What is this indicative of? I had replaced the handle cover and was wonering if I had pinched the wires on re-assembly.
Any ideas?
Re: t123 torch problem, burnt wires
Postby jimcolt » Wed Nov 22, 2017 8:41 am
The red wires are the nozzle connection (positive DC from the power supply). Looks like something was pinched or chafed inside the handle.....likely there was full cutting power shorted between the negative lead (brass nut) and the red wires. You can get the service manual at the www.hypertherm.com website . Jim Colt Hypertherm Also, can contact tech service for help, advice: [email protected] or 1 800 643 9878
i_r_machinist
Postby i_r_machinist » Mon Nov 27, 2017 9:55 am
Thanks Jim!
Users browsing this forum: No registered users and 5 guests
