It is currently Fri Sep 21, 2018 8:12 am
Hypertherm 85-Fine Tip Consumables-.125 Aluminum
csplazma1
Postby csplazma1 » Thu Nov 16, 2017 10:17 am
So has anyone tried to use Fine tip consumables on .125 Aluminum??? I use them on 3/16 mild steel and thought instead of changing out consumables I would try them. Any Ideas on settings that might get me in the ball park or should I steer clear?
C&S PlaZma Metal Works
LDR Motion Systems 4X8 Water Bladder
Hypertherm Powermax 85 Machine Torch
Everlast PowerPlasma 60 Handheld Torch
Thunder Laser NOVA 51
Re: Hypertherm 85-Fine Tip Consumables-.125 Aluminum
Postby tcaudle » Fri Nov 17, 2017 5:48 pm
If there is not a cut chart for it then is not recommended.
