powermax 1000 torch..... (jimcolt )
hardsteel
Post by hardsteel »
hello guys .
i got 3 hypertherm powermax 85 torch in stock and i need to install one of them in my new powermax 1000 G3 because i got a lot of consumable in stock too so ,please is there any way to install hypertherm poweramx 85 torch into hypertherm powermax 1000 g3?.......
i heard that can be installed with but experience with before .....
any help will appreciated .
Re: powermax 1000 torch..... (jimcolt )
No, it is not compatible with the Powermax1000. The wiring connectors and air fittings are different. You can get the same torch (Duramax) that is used as a retrofit torch that will plug into the Powermax connectors. You can find it on the the Hypertherm website. Jim Colt Hypertherm
hardsteel
Post by hardsteel »
thank you so much
