Question on Powermax 45
OTHill
Post by OTHill »
I've been running a PM 65 with hand torch on my plasma table. I want to run it with a PM 45 with a hand held torch now.What changes do I need to make? Maybe just the trigger bypass the same as the 65? Does the 45 have the voltage divider? What should it be set at? I have the Candcnc Blade runner.
Re: Question on Powermax 45
Post by jimcolt »
The connections will be similar to the connections with the Powermax65. I suggest consulting with CandCNC.com to ensure the connections are correct. Jim Colt Hypertherm
tcaudle
Post by tcaudle »
The 45 has the same CPC connector with the voltage divider and START and Transfer pairs so your MIC-01 cable will work the same. You will still need to bypass the hand torch safety circuit The 45 has just a 50:1 divide ratio so the PWM divider setting has to be on the 50:1 . That may be what you already have it at if your 65 was set at 50:1 (default from factory)
OTHill
Post by OTHill »
Thanks Jim and Tom.
