I'm not sure if I'm asking this right but. I have a PM45 with a machine torch. I have it hooked up to a proma THC. I have the start/stop and voltage divider attached. Where should the ground pin go?
Ground on cnc port
Re: Ground on cnc port
The ground is if you use a shielded cable and want to ground the shield for noise suppression. 99.9 % of the time it is unused. Jim Colt Hypertherm
Thanks Jim
