45xp machine Torch Diameter?
Hi, is the machine torch on the 45xp 1 3/8" diameter?
Re: 45xp machine Torch Diameter?
I had posed that question to Jim some time back and he said that was a standard size for machine torches.
- see&see
Just received the 45xp Part #088121 with machine torch today and it's the same diameter (1 3/8") as my PM 85 2 piece Duramax machine torch but the 45XP machine torch is plastic 12 inches long. The new body is split halves screwed together. In the picture I have the top half of the PM85 Duramax machine torch left after I removed it to fashion the mini torch.
The 45XP machine torch is 3" shorter than the Duramax machine torch fully assembled but still a full 12 inches long. Jim has said the Duramax machine torch #228790 will work on the 45XP. Just take the top body off and shorten it to the mini. But the 228790 torch and cable will set you back about $700.
- Attachments
- 45XP Torch.JPG (109.54 KiB) Viewed 606 times
You marry into the PlasmaCam family and must accept the fact your software and hardware are proprietary. It's a for better or for worse engagement with overwhelming security. PlasmaCam controls the computer, table, hardware to their advantage IMO.
Thanks, Got mine a while back and fits my mount perfectly.
Whats the best option part number for a hand torch with a short cable (20'/25') purchase? The models I see listed for the 45xp don't look like they have the quick connect... must the connector be purchased separately?
- see&see
I'm going with the ---059482 [1/pk] PMX65/85/105 180 DEGREE MINI MACHINE TORCH ASSEMBLY 25'__ Hyper4Less $513.00
Hypertherm 059482 Ready to plug & play on the 45XP..
I already have a machine torch. I found the correct Hypertherm stock number.see&see wrote:I'm going with the ---059482 [1/pk] PMX65/85/105 180 DEGREE MINI MACHINE TORCH ASSEMBLY 25'__ Hyper4Less $513.00
Hypertherm Duramax Lock 75° Hand Torch 45XP 088164
