dolphin keys and welcome
- ctorres3120
this court for a client what their main decoration are dolphins
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
Hypertherm PowerMax 1250
http://www.facebook.com/ctorresp?ref=tn_tnmn
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
Re: dolphin keys and welcome
That is incredible. Thank You Very Much.
Mike
Mike
http://www.PenningtonFab.com
Torchmate 3 with Accumove 3
Hypertherm 1250
Hypertherm 380
Lincoln V205T Tig
Lincoln wirematic 250
Eastwood 175 with Spoolgun
Eastwood 135 Mig
Hypertherm 1250
Hypertherm 380
Lincoln V205T Tig
Eastwood 135 Mig
- GoingCustom
Thank you
Thanks for the file - my wife's best friend will love this key holder. I have one quick question - What program did you use to make the dxf file? The reason I ask is that when I downloaded the file it came in with 11,026 nodes and 5513 subpaths. Not really an issue as I was able to join the subpaths and reduce the nodes.
Thanks again!!
Gerry
Thanks again!!
Gerry
- Oldsarge
Thanks for the file! You post some really great files, and I appreciate it!
Oldsarge
Oldsarge
6x12 Home Built Table
Hypertherm PowerMax 85
- mekanic13
Looks great! Thanks
- Diverdude
- 4R8
that's a beautiful piece, thanks Carlos!
- Zippo
Thanks for posting
- kgc1031
Nice! Is it possible to get it in a dxf fle?
- Larry83301
Just download the file and UN-ZIP it.
- ctorres3120
dfx file
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
thanks for sharing a great file.
- steel 35
Another Very nice one pulled from the archives I never found, Thanks for digging it up; Sharing it was great as well. Thank you
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
tirediron wrote:Thanks for the file - my wife's best friend will love this key holder. I have one quick question - What program did you use to make the dxf file? The reason I ask is that when I downloaded the file it came in with 11,026 nodes and 5513 subpaths. Not really an issue as I was able to join the subpaths and reduce the nodes.
Thanks again!!
Gerry
Do you have the cleaned up file? I would love a copy as I can't get it to clean up so I can cut it. Thank you.
- ctorres3120
This was one of my first jobs and I turned it into dxf in Master Cam and then I was in SolidWorks, but now I work in reaConverterMrsSavage wrote:tirediron wrote:Thanks for the file - my wife's best friend will love this key holder. I have one quick question - What program did you use to make the dxf file? The reason I ask is that when I downloaded the file it came in with 11,026 nodes and 5513 subpaths. Not really an issue as I was able to join the subpaths and reduce the nodes.
Thanks again!!
Gerry
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
