WESTERN WALL SWITCH/OUTLET COVERS
Does anyone have any western wall outlet covers to fit over a plug?? I am new to CADD and haven't figured out how to put images on top of the plug and switchplate dxf that i found on here.....Let me know. Thanks!!!!
- ben de lappe
Re: WESTERN WALL SWITCH/OUTLET COVERS
the only system I personally know is Torchmate cad. with it, one would use the " weld " function to make it one object. if you wish let me see what you have and I would be happy to help.
THANK YOU SO MUCH!!!!! I WILL DEFINATELY USE THIS ONE AND TAKE THE OTHER RESPONSE I GOT AND USE THE TACK WELD METHOD WHICH WILL WORK GREAT TOO!!!!! THANKS!!!!!
- Weldtutor
A cowboy/girl hat might work also!
Save the DXFs, then try changing the hat creases or outline.
Playing with the drawing helps you to learn tricks!
In my previous post. at the top of the original cover plate, I did a line "BREAK" in my CAD program, imported a cactus image & pasted it above the plate, then joined the nodes between the 2 images.
- Weldtutor
Cowboy boot on outlet cover.
THANK YOU WELD TUTOR!!!!!! YOU ARE AWESOME JUST WHAT I WAS LOOKING FOR!!!!
- Weldtutor
You're welcome.
Pleased to be able to share.
Very cool idea. Going to put in my ""Man Cave". Thanks
- ctorres3120
Here are the horses
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
Hypertherm PowerMax 1250
http://www.facebook.com/ctorresp?ref=tn_tnmn
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
thanks for all the file posts
Hay All
Maybe this will help some one. Hear is the blank wall plate templates, both standard and Decor so you can add any file you want to attach to it.
Rod S in AZ
Nice stuff and great templates, thank you so much for the share.
How would one go about curving the edges, so the plates fit flush to the wall? Cut laminate dies, and do it in a press? Better ideas? I'd like to offer something with fitment more like a "real" wall plate.
Double tap...
I made a 2 piece die for my 25T iron worker, works great.
PlasmaCam DHC2
Hyperthem PM65
Edwards 25T Ironworker
Hyperthem PM65
bam thanks
Yahoozles! Great share!
Would you mind sharing info/photos on how you made that? Was it a laminate die, or did you mill it/have it milled?Bobcat320 wrote:I made a 2 piece die for my 25T iron worker, works great.
Very nice files. Many thanks.
- Larry83301
Where I worked the sheet metal guys had one piece dies and a block of hard rubber about 4 or 5" thick for the top die. They just pressed down and formed parts with no scratches. Just a thought, saves making a top die.Bobcat320 wrote:I made a 2 piece die for my 25T iron worker, works great.
- mekanic13
Thanks for the files! Very helpful!
Mike
Mike
Thank you for the files
Have a quick question about the outlet covers where it says 22" cut by the covers what does that refer to. The ones that fit my switch and outlet at my house are the ones that say 22" cut by them the other ones don't work. Was just curious.
At a quick glance, I would assume it refers to the total inches of cut to make that part......
