Gas Cylinder Wall Bracket
- MetalheadRK
Hello Everyone
I made this yesterday and thought it worked pretty well so I wanted to post it in case someone else was running into the same problem I was. I needed a wall mount for my Argon/Co2 cylinder and the stuff online was too expensive or not really what I wanted so I decided to make my own. Have plasma cutter, why not, right?
This fits a 7" cylinder (snug fit) and I split some tubing to make a cushion for the edges. You can make it larger or smaller to fit the size tank you are using. The strap came from Lowe's and cost $7.00 for 2.
The only down side is, I created it in PlasmaCam so the file is a .pcm. If that is what you have, great. If there is someone out there that can convert it to a .dxf, more will be able to use it.
Richard
Richard
Re: Gas Cylinder Wall Bracket
nice job i know what i am making this weekend thanks
VERY NICE, THANKS!
- JJsCustomDesigns
Thats clever. I like it
PM me with details
PM me with details
Well Done!!!
Can't download, I have an older version plasmacam
Please post as a DXF, IF YOU HAVE A PLASMACAM I THINK YOUCAN SAVE AS DXF OR EXPORT AS DXF THANKS
I second that!
- BrianMick
Cotton wrote:I second that!
added...........GMFAB wrote:Please post as a DXF, IF YOU HAVE A PLASMACAM I THINK YOUCAN SAVE AS DXF OR EXPORT AS DXF THANKS
www.midwayiron.com
www.midwayiron.com
- MetalheadRK
Here is the file. My PlasmaCam doesn't give me the option to convert to DXF so I redrew it. Hope you like.
Richard
Richard
4x4 PlasmaCam
Hypertherm 45
Eastwood 175 MIG welder
Hypertherm 45
- MetalheadRK
Forgot to say, this is for 16ga. material.
4x4 PlasmaCam
Hypertherm 45
Hypertherm 45
Thanks for sharing.
- Francisco
Neat design, well thought out!Many thanks for sharing it.
Great, thanks for the conversions.
- BlackDogMetalWorx
MetalheadRK wrote:Here is the file. My PlasmaCam doesn't give me the option to convert to DXF so I redrew it. Hope you like.
Richard
You just have to use the export option in the file menu, then choose dxf as file type.
thanks for sharing
- wishiwastorching
I have absolutely no use for such a bracket yet but I have to say that is a pretty awesome design! Our little tables are so handy for so so much stuff in just about every genre of life. I love it!!!
Thanks for posting
Hypertherm 65
Hypertherm 65
- Unvevo
Very nice
- edclayton1
Thanks, i can use this for sure. very well done.
Home Built 4 * 8 table
Bladerunner
Miller Syncrowave 250 TIG welder
Miller 211 Wirefeed Welder
Bridgeport Mill
Jet 13 * 40 Lathe
Hypertherm Powermax 65
80 gal 2 stage 175 PSI Emax air Compressor
Bladerunner
Bridgeport Mill
Jet 13 * 40 Lathe
Thanks. Will cut a couple for my extra bottles.
- steel 35
Another from the past I Had never found, but its exactly what I have wanted for picking up and returning tanks in the back of a pickup, I always hated that sound when they roll and slide around even in a work truck
Thanks for sharing !
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
Just to drag this one up from the depths of time.
Thank you for sharing this, I’ve a welding trolley to make for my ESAB, and a pair of these on the back would be brilliant!!
This is cool. I may add a couple to a hand truck to make moving bottles a little easier/safer. Thank you for sharing!
I like it im gonna make a few this weekend
