Need help with drawing railing panel
cutterguy
Post by cutterguy »
I need some help with designing a stair case railing. If anyone can point me in the right direction I would greatly appreciate it. I can email the dxf. of the panel sizes to any one that's intrested.
Doug
redneckgateart
Re: Need help with drawing railing panel
Post by redneckgateart »
Doug,
Can you be a little more specific regarding the type of help that you need? Are you having trouble with the dimensions or the design? ...ie. is it a rise/run issue or artwork related? Will the body of the panel be an artwork scene or balusters?
Clark
cutterguy
Post by cutterguy »
I have the outside dimensions of the panels. All I need is someone to fill in the artwork. My customer is not specific about it except that he doesn't want any bears. We are hoping to fill the entire railing with a wildlife scene with no balesters. The main railings will be in 2 pieces with 2 small pieces at the to and bottom.
Doug
Check out railing inserts from cascade metal designs. His are great!
http://customdxffiles.com/dxf-files/railing-inserts-1
http://customdxffiles.com/dxf-files/railing-inserts-2
Would something like this work? If not he has more! :) :) 26 of these don't have bears.
cutterguy
Post by cutterguy »
Thanks for the ideas Larry83301. The problem is that because this is a stair case railing everything needs to be at an angle. I have already contacted Cascade Metal Designs and Jason is to busy to give this project attention.
Doug
JJsCustomDesigns
Post by JJsCustomDesigns »
Cant you take Jason designs and skew ( is that the right term?) the insert to fit in your angled railing? SignTorch has amn awesome bundle that you can make your own wildlife scenes with too.
PM me with details
captdick
Post by captdick »
I can distort if you have file and size
