I'm no artist, so I'm useless when it comes to sharing art files, but sometimes people have me build things that don't have to be pretty. This is the pattern I used to build a replacement battery box cover for an International eagle. (Took a few attempts to get the slots right.) I'll post some finished product pics later. Sorry for those of you that can't open pcm. files. I'm running Plasma Cam Design Edge and can't export dxf files yet. (That's another $1000.00 upgrade) and I'm waiting till the new tax season starts. Maybe someone else on the forum would be kind enough to convert it over. Hope someone can use it.
Battery Box Cover 1998 International Eagle
Reason: added dxf and sample pic
Re: Battery Box Cover 1998 International Eagle
I was going to convert it, but PC 3.11 won't open it.
- BrianMick
That is because it was created with designedge software.......Older versions can not open a designedge pcm unless you export as a 3.11 or earlier pcm... or dxfMountain Home wrote:I was going to convert it, but PC 3.11 won't open it.
www.midwayiron.com
www.midwayiron.com
- BrianMick
How much did you pay for your version? I payed 2000 for the base program and got the export feature with it....I guess I just thought that would naturally come with.......can you import dxfs?prattswelding wrote:I'm no artist, so I'm useless when it comes to sharing art files, but sometimes people have me build things that don't have to be pretty. This is the pattern I used to build a replacement battery box cover for an International eagle. (Took a few attempts to get the slots right.) I'll post some finished product pics later. Sorry for those of you that can't open pcm. files. I'm running Plasma Cam Design Edge and can't export dxf files yet. (That's another $1000.00 upgrade) and I'm waiting till the new tax season starts. Maybe someone else on the forum would be kind enough to convert it over. Hope someone can use it.
www.midwayiron.com
www.midwayiron.com
I'm running Design Edge version 4.09, My base program was $2000.00 also. My advanced height control was an additional $2,000.00, and if I want the Advanced Cut Control, and Advanced Design they are $1,000.00 each. I've done enough spending as far as deductions go this year, so I'm waiting till after Jan 1st to make that next purchase. When I spoke with PC Tech Support, they told me in order to export in dxf format, I would need the advanced Design Software. I can import dxf just fine, I just usually end up having to explode the drawing and relink the segments to import cut paths.
- BrianMick
hmmm thats curious because I can export dxfs with the 2000 dollar setup
www.midwayiron.com
www.midwayiron.com
Yeah, Now you've got me curious about that. Here are some pics of the finished box. It wasn't perfect, but sure got the job done and helped out the guy that was in a pinch.
Wow, am I glad I didn't take the bait in that trap.prattswelding wrote:I'm running Design Edge version 4.09, My base program was $2000.00 also. My advanced height control was an additional $2,000.00, and if I want the Advanced Cut Control, and Advanced Design they are $1,000.00 each. I've done enough spending as far as deductions go this year, so I'm waiting till after Jan 1st to make that next purchase. When I spoke with PC Tech Support, they told me in order to export in dxf format, I would need the advanced Design Software. I can import dxf just fine, I just usually end up having to explode the drawing and relink the segments to import cut paths.
- BrianMick
But I have all of those features and only paid the 2000 dollars........Unless they changed their Marketing of the product since I bought it I don't know why that isMountain Home wrote:Wow, am I glad I didn't take the bait in that trap.prattswelding wrote:I'm running Design Edge version 4.09, My base program was $2000.00 also. My advanced height control was an additional $2,000.00, and if I want the Advanced Cut Control, and Advanced Design they are $1,000.00 each. I've done enough spending as far as deductions go this year, so I'm waiting till after Jan 1st to make that next purchase. When I spoke with PC Tech Support, they told me in order to export in dxf format, I would need the advanced Design Software. I can import dxf just fine, I just usually end up having to explode the drawing and relink the segments to import cut paths.
www.midwayiron.com
www.midwayiron.com
