It is currently Thu Sep 20, 2018 10:50 am
Vise Grips Rack
MetalTorcher
Re: Vise Grips Rack
Postby MetalTorcher » Sun May 11, 2014 7:12 pm
CNCCAJUN wrote:Nice file, but I just realized the "G" in GRIPS is not all there . . .
File looks good to me, not sure what you mean.
Jason Lyon
PlasmaCAM DHC2
Advanced DesignEdge
Hypertherm Powermax 1000
Everlast PowerMTS 251si
Torturing metal since 2014
d bushey
Re: Vise Grips Rack
Postby d bushey » Sun May 11, 2014 9:45 pm
Definitely saving that. Thanks
CNCCAJUN
Re: Vise Grips Rack
Postby CNCCAJUN » Sun May 11, 2014 9:50 pm
When I open in AutoCAD the bottom of the "G" is missing in GRIPS :?
When I open with DraftSight everything is just fine . . . :? :? :? :? :?
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Largemouthlou
Re: Vise Grips Rack
Postby Largemouthlou » Mon May 12, 2014 7:07 am
Nice original file, love the hanging one as well!! Very nice thanks,,
Steve, the G was all there when I opened with corel..
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
MGardner
Re: Vise Grips Rack
Postby MGardner » Mon May 12, 2014 5:58 pm
This will be put to GREAT use.
THANK YOU very much
Mike
agarwelding
Re: Vise Grips Rack
Postby agarwelding » Mon May 12, 2014 9:25 pm
Thanks for sharing the file.
DezertBlingMoto
Re: Vise Grips Rack
Postby DezertBlingMoto » Mon May 12, 2014 11:15 pm
thank you so much for the post of this tool rack . highly appreciated .Anyone happen to know the actual dimension's ? when I imported turned out to be 15X5". Anyone got anything different ? thxs in advance
billyeagley
Re: Vise Grips Rack
Postby billyeagley » Sun May 18, 2014 4:48 pm
Very practical file! Thanks!
PlasmaCAM 5x10 (Samson) - DesignEdge - Hypertherm Powermax 65
tch5182
Re: Vise Grips Rack
Postby tch5182 » Mon May 26, 2014 6:22 am
Thanks! Maybe I will be able to find them when I need them now. I spend more time looking for vise grips and tape measures than I do working.
radnurse68
Re: Vise Grips Rack
Postby radnurse68 » Mon Jun 02, 2014 1:54 am
Thanks!!!
Stephen W. Sparks RN,CRN
Creating Sparks Metal Worx
Arclight Dynamics Arc Pro 12000 5X10
Linux, Sheetcam, Inkscape, Solid Edge
MIllermatic 175
AHP Alphatig 200X
Kool Koat 3.0 DPW
"Ridin around having a big time!"
crazy59860
Re: Vise Grips Rack
Postby crazy59860 » Thu Jun 05, 2014 1:24 pm
very nice.........will have to show hubby
Toni
HammerDownJustin
Re: Vise Grips Rack
Postby HammerDownJustin » Thu Jun 05, 2014 11:52 pm
Wish I had that many pairs of vice grips to justify making this..lol
Miller 251 Mig
chattacuda
Re: Vise Grips Rack
Postby chattacuda » Tue Jun 10, 2014 8:01 am
Thanks for the file. What a great idea! I made two of them, then slightly modified the file and made a couple of hangers for my most often used air tools out of 11 and 14 ga. Worked great. Thanks again
chattacuda from Dayton, Tennessee
CandCNC electronics, Precision Plasma V rail gantry, homemade 4'x8' water table
Hyperthem 45, Sheetcam, mach3, Corel Draw
karltatt2
Re: Vise Grips Rack
Postby karltatt2 » Wed Oct 08, 2014 4:27 pm
[quote="mdoffroad"]15 Downloads and not one thank you.......whats wrong with some of you people!
great idea m8ty thank you for sharing
CNCCAJUN
Re: Vise Grips Rack
Postby CNCCAJUN » Wed Oct 08, 2014 4:59 pm
Thank you again . . . . . this is the first file I have cut using SheetCAM . . . SigmaNEST is being put rest . . .
Dynatorch 4X4 XLS
PowerMAX 85
Thumper
Re: Vise Grips Rack
Postby Thumper » Wed Oct 08, 2014 5:14 pm
Thanks for the file,,,
CNCCAJUN
Re: Vise Grips Rack
Postby CNCCAJUN » Wed Oct 08, 2014 9:09 pm
Redlunn wrote:Yeah, my first post!
Here is a simple rack for holding various vise grips. I don't have any type of brake so I cut reliefs at the bend points. I plan to weld it underneath my welding table.
Redlunn
Hello Redlunn;
The slender rectangular boxes are relief points to make bending possible without a brake, if using a brake can I assume the center of those boxes would be the bend lines?
Dynatorch 4X4 XLS
PowerMAX 85
ron
Re: Vise Grips Rack
Postby ron » Thu Oct 09, 2014 10:59 am
GREAT IDEA AND I THINK EVERYONE WILL APPRECIATE THE RACK. THANKS
Jeff M
Re: Vise Grips Rack
Postby Jeff M » Sat Oct 11, 2014 3:16 am
cool,
thanks for the post.
Jeff M
metalworxfabricators
Re: Vise Grips Rack
Postby metalworxfabricators » Sat Oct 11, 2014 3:20 pm
Super nice work. You did good.
Thank You,
Metalworx Fabriicators
Metalworx Fabricators
ArcLight Dynamics
Hypertherm Powermax 45
CNCCAJUN
Re: Vise Grips Rack
Postby CNCCAJUN » Sat Oct 11, 2014 3:35 pm
Great file, but I did I make some changes so they could be used by more people . . . :D :D :D
I added 2" height to the back & (4) 1/4" holes . . .
Now they can be mounted to a wall, pegboard, etc . . . and still function as designed . . .
I eliminated the relief slots and had them bent on a large brake.
Also thanks to your idea I think can design a clamp rack for small Bessy Clamps for the wood shop . . .
Thanks for posting . . . .
Dynatorch 4X4 XLS
PowerMAX 85
AIRFLOWKID
Re: Vise Grips Rack
Postby AIRFLOWKID » Tue Nov 25, 2014 9:53 pm
Thanks so much!!!!
Tim :ugeek:
kkroger
Re: Vise Grips Rack
Postby kkroger » Wed Nov 26, 2014 8:18 pm
Designed something very similar for Air Tools, then discovered that someone is already selling something similar.
I put Keyholes in for hanging larger circle with a slot above.
kkroger
Re: Vise Grips Rack
Postby kkroger » Fri Nov 28, 2014 11:30 pm
Here is the one I designed. I did a Vise Grip Rack so the tools hang from the adjustment screw...
I use 18Ga and bend them with an HF Brake. Look sellable at swap meets.
Corfabrication
Re: Vise Grips Rack
Postby Corfabrication » Sat Nov 29, 2014 10:44 pm
HammerDownJustin wrote:Wish I had that many pairs of vice grips to justify making this..lol
I think this gives a reason to buy more vise grips.
Users browsing this forum: 2015cmax, Chuckles5251, eric812, Google Adsense [Bot], karltatt2, MCCORD07, Ryan, Searchman, thomp327msu and 26 guests
