I Shouldn't Post This...
- steelfx
This 3-piece (four, if you make the pan) is so damn basic, but it works! Once the ends are in place, it can't collapse.
I used 7awg for the top & 10 or 11 awg for the ends. No hardware, hinges or tools needed.
You can add any design you want for the grill top OR ends. Field tested and it does work really well.
Ya'll Have a Great Weekend!
Bill
Bill
- dreamer
Re: I Shouldn't Post This...
nice file Bill thanks..........Harold
- Loyd
Bill, That is really nice. Sometimes the most simple things are best!
Great job and thanks.
Loyd
Loyd
Thanks Bill. This is Great.
http://www.PenningtonFab.com
Torchmate 3 with Accumove 3
Hypertherm 1250
Hypertherm 380
Lincoln V205T Tig
Lincoln wirematic 250
Eastwood 175 with Spoolgun
Eastwood 135 Mig
Hypertherm 1250
Hypertherm 380
Lincoln V205T Tig
Eastwood 135 Mig
Bill that is great.
A small canvas shopping bag will probably carry all that .
Now how in the hell did you have time with all that shipping stuff to Canada ,coloring your own projects and answering every phone call from buyers to do something so simple
This is what we call a multi-tasker!!!
Now ,I have one question ,how thin of gauge do you think we could use for the top grill piece before it becomes a warped mess... thinking of what we have in spare steel is the reason for the question.
Gary
Gary
- steelfx
Gary,glgsales wrote:Bill that is great.
Gary
If you make it smaller, you could use 10awg for the top, but NOT the way it's drawn...you'd need to burn a different grill pattern e.g. holes, diagonal slots, etc. The way the top is drawn above is the worst possible way to do it because of heat warpage while cooking. But, I couldn't find the last file I did, which is represented in the photo...of diagonal slots. That configuration makes it easy to use a spatula from almost any direction. But, I found that 3/16" plate works best for the top. Just be sure that the receiver slots on each end are slightly (15-20%) wider than the gauge steel used for the ends. That will allow the ends to splay out for support.
Got it thanks bill.
Makes sense... too
Makes sense... too
Very nice. Thanks much.
- Dustan
awesome!! awesome!! Thanks a bunch Bill !! Nice little stove indeed
Krazy Kutz metal designs
- steelfx
- jmsrbrt
Tried it and an FYI to anyone who might cut this, be careful about the slot that holds the legs. Too wide, and your legs will lower the cooking surface onto the fire. And THANKS Bill...I think it will fit in my Goldwing's trunk.
- steelfx
The leg gap is a little touchy...mine was set up for 10awg ends & I cut the 7awg top with fine-cut consumables. Worked out just fine with about a 20-25 degree outward cant to each end. You could also weld a small section of .5" Sq. Stock, maybe 3-4" long & position it on the bottom of the grill, next to the end-piece slot, to prevent "over-splay".
- akpilot
I make mine a little different, but same idea
- BrianMick
I was thinking with bills design you could resize it and make the top a pan also that just fits like a box and the legs would fit inside for transportation? I am going to try this and will post picks if it works good
www.midwayiron.com
www.midwayiron.com
That is the craziest grass I have ever seen. Is the HOT big enough for a chicken wing to fall through? I think I am going to have to make one of these, but clearly I am going to have to customize it like you did.akpilot wrote:I make mine a little different, but same idea
- akpilot
Ya I wish that crazy grass would "die off" so the green stuff could grow!!RClippa wrote:That is the craziest grass I have ever seen. Is the HOT big enough for a chicken wing to fall through? I think I am going to have to make one of these, but clearly I am going to have to customize it like you did.akpilot wrote:I make mine a little different, but same idea
Cool thank you.
any others? i especially like akpilot's design!akpilot wrote:I make mine a little different, but same idea
Nalin Manufacturing, LLC
Hypertherm Powermax 85
Bulltear Starlab 4'x8'
- wapitismith
I used your basic design and made one for my brother-in-law. You can't build fires on the ground around the riveres out here, so this and a fire pan are very nice equipment. Thanks for the design!!
WapitiSmith
"There are strange things done in the midnight sun..."
