Snoopy Mailbox Topper
Jfile
Post by Jfile »
Here is a Snoopy mailbox topper that I recently did for a friend. The original DXF file was created by Stan at DXF Graphics. Permission was given to share on this site since it's not a graphic that he normally sells on his site. I hate that my first share is not a file that I actually created but at least I was a small part of the original idea. :)
If you plan to cut and use for a different type of project, you will need to ad his ear(s). I asked Stan to leave it off because my friend was going to paint the ear on each side of the mailbox. I took a picture of it before he had a chance to do that. He also mentioned possibly using some vinyl to make ears so they could flap around in the wind. Everything was made using 14 gauge including the brackets that I bent and welded up. The Snoopy was scaled and cut at approximately 14 inches long for the mailbox that it was mounted to.
Snoopy Mailbox Topper.svg
LDR 4'x4' Water Table
Command CNC Linux Controller
Plate Marker
Power Max 45xp w/ Machine Torch & Hand Torch
2 Stage filter, Motorguard filter & HF Ref Dryer
InkScape / SheetCam
omng945
Re: Snoopy Mailbox Topper
Post by omng945 »
Cool little Snoopy
gbrown6363
Post by gbrown6363 »
Can someone convert this to dxf
urbnsr
Post by urbnsr »
DXF attached.
Snoopy Mailbox Topper.dxf
ken4952
Post by ken4952 »
Great idea.
Ken
Rex
Post by Rex »
Thanks for sharing
Hypertherm 65
david jordan
Post by david jordan »
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
swcfab
Post by swcfab »
I've always loved Snoopy. This is fantastic!
dcdaustin
Post by dcdaustin »
Nice
fasteddie
Post by fasteddie »
Great idea.Thanks.
