Get 'N' Spooled Sign - For the Fishermen
I have had nothing but failure trying to get this to a decent SVG
It seems to trace in so many layers that I can't get a good single line image from it
can anyone help with this one ? It has kicked my Butt for over a month
Arc Pro 4800
PowerMax 45
Mach 3, Sheet Cam
Inkscape, Paint.net
PowerMax 45
Mach 3, Sheet Cam
Inkscape, Paint.net
- rdj357
Re: Looking for some help
Here's what I came up with over coffee.
(Edit: Works better when your 5 year old pestering you doesn't make you forget to bridge the text before you upload!)
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
Thanks for sharing
- Rem300wm
Hello to All
that is a cool design,thank you for sharing the file.
Rem.
Rem.
great share..thank you
Must have been a Large cup of Coffee !!!!
Thank you SO MUCH, you are AWESOME !!!!!!
Arc Pro 4800
PowerMax 45
Mach 3, Sheet Cam
Inkscape, Paint.net
PowerMax 45
Mach 3, Sheet Cam
Inkscape, Paint.net
Thank you : very nice file !!
Thanks for sharing, I really like the finish on your part!
- rdj357
It was a medium size cup of coffee.
Bradley, the finish on that simulation is what it would look like if cut from corten steel and left to naturally rust. A similar result would be obtained by using cold rolled steel.
Robert Johnson
- steel 35
I think I have 1 extra nail for that; THANKS
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
Robert, great work. Thanks
Very nice! Thanks!!
Re: Get 'N' Spooled Sign - For the Fishermen
Nice, thanks for the share!!
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
CandCnC electronics
Thanks for sharing. Coffee is what helps ?
- rdj357
Definitely. It's what keeps me from being a grumpy old guy well at least it takes the edge off.Searchman wrote:Thanks for sharing. Coffee is what helps ?
Robert Johnson
nice job !
