P51 Mustang or Spitfire Plane DXF file
1eyedjim
Post by 1eyedjim »
Hello
Looking for a Spitfire file please? Thanks
harrymorley
Re: Looking for Spitfire Plane file
Post by harrymorley »
Im hoping this will work for ya..the bullseyes are drops. Could use some detail just aft of the exhausts stacks. Also under them
p51.dxf
harrymorley
heres is a better one with emblems..again , lots of drops...gonna need bridging if its one layer
P51 mustang 2.1.dxf
1eyedjim
Post by 1eyedjim »
Many many thanks. I will add tabs across the drop outs. Rob
Rickzink
Post by Rickzink »
Im trying to download this P51 but when I try to open it, nothing shows up.
cuttinparts
Re: P51 Mustang or Spitfire Plane DXF file
Post by cuttinparts »
Which one are you trying to open? What software are you opening it in?
Rickzink
Post by Rickzink »
cuttinparts wrote: Tue Dec 13, 2022 8:41 am Which one are you trying to open? What software are you opening it in?
p1 mustang 2.0. I'm trying to open it in inkscape.
cuttinparts
Rickzink wrote: Wed Dec 14, 2022 11:34 am
I find Inkscape does not play nice with a lot of dxf files, it definitely prefers svg format. I converted the dxf to svg for you and it seems to open fine in Inkscape so give this one a try.
if you have problems with dxf files not opening in the future use this tool to convert to svg https://convertio.co/ works 99% of the time. Learned this from the Inscape forum here on Plasmaspider :Like :Like
P51 mustang 2.1.svg
