F Bomb Bottle Opener
Saj455
Post by Saj455 »
After cutting out, grind the round part on a angle.
F bomb.dxf
otisa2007
Re: F Bomb Bottle Opener
Post by otisa2007 »
nice thanks
weldingchick2000
Post by weldingchick2000 »
pretty cool
Linfield Garage
Post by Linfield Garage »
Very cool, thanks for uploading
Lightning_strike
Post by Lightning_strike »
What thickness would you suggest?
Samson 510
Hypertherm powermax 1250
campbell hausfeld 60 gal
Hobart ironman 230 :Yay
3/4" blade band saw
4ft finger brake
Miller diversion 180
Millermatic 140
DezertBlingMoto
Post by DezertBlingMoto »
Are you guys cutting bottle openers on stainless ? I'm just curious …………………………………… thanks
Lightning_strike
Bump
Samson 510
3/4" blade band saw
4ft finger brake
Millermatic 140
Hunters 4x4
Post by Hunters 4x4 »
This is awesome!
cajones
Post by cajones »
Slight re-hash of the file
F Bomb.dxf
GuthrieFab
Post by GuthrieFab »
Thanks for sharing.
david jordan
Post by david jordan »
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Lightning_strike
How did you get that finish?
Samson 510
3/4" blade band saw
4ft finger brake
Millermatic 140
Plasron
Post by Plasron »
I'm new to CNC Plasma cutting, I tried cutting this but couldn't get the F to cut out, could you share gauge of metal used and cut speed.
Ron
Windows 10 64 bit laptop
Gorilla 4x4 table
Proma torch height control
Gecko mini gender changer to USB
Everlast 80 S Plasma cutter
Mach3
Inkscape
QCAD.
cajones
Post by cajones »
Lightning_strike wrote: Fri Sep 20, 2019 6:50 pm How did you get that finish?
Its just cold rolled 14ga with a quick wet/dry sand with 320 in one direction, not really "finished" so much...
