different designs over the last years - part One
nuno115
Post by nuno115 »
sharing different designs that I did over the year
USE WHAT YOU CAN, IGNORE THE REST...
braket for monitor vertical.dxf
braket for david shooting skids.dxf
BETO 12x24 Oval Insert 10s.dxf
58.DXF
4x4 shim with 3quarter hole.dxf
3in Hand Rail base w 3 hole.dxf
11in circle with 2in hole within.dxf
3b.dxf
2x2 shim with 3quarter hole.dxf
2x5 and 2x4 steel cap.dxf
otisa2007
Re: different designs over the last years - part One
Post by otisa2007 »
thankyou for the shares
seajinx
Post by seajinx »
nuno115 wrote:sharing different designs that I did over the year
Images would assist in getting comments and downloads. just saying.
Ronz2Busy
Post by Ronz2Busy »
Thank You! I like the oval insert!
dholt87
Post by dholt87 »
Thanks for the file share!
whiskeymike
Post by whiskeymike »
Nuno, where about are you located? Austin/Bastrop here. (Noticed the Beto sign)
nuno115
Post by nuno115 »
whiskeymike wrote:Nuno, where about are you located? Austin/Bastrop here. (Noticed the Beto sign)
We are in Yonkers, NY
Beto is the abreviation of ALBERTO - a friend of ours.
whiskeymike
Ah, cool. here in Texas, a guy called Beto is running for Ted Cruz’s senate seat, so I assumed you were in Texas.
