Locomotive Modifications
Thank's to Brian Micks for the file that had the main picture. My nephew is infactuated with trains of all kinds so I used Brians and modified it to a personal wall plack Thank's Brian.
Rod S in AZ
- BrianMick
Re: Locomotive Modifications
acctiually that is not my file I believe I just steered you to the thread.......but thanks anyway.....Eagle Mtn D&D wrote:Thank's to Brian Micks for the file that had the main picture. My nephew is infactuated with trains of all kinds so I used Brians and modified it to a personal wall plack Thank's Brian.
by the way nice work...
www.midwayiron.com
www.midwayiron.com
Well thats is ok, so who ever drew the main file I give a big thank's to. I know that my nephew will like the wall plaque.
I want to thank AZWOODMAN for the first post Thanks
Rod S in AZ
try this
I hope you don't mind but I cleaned up the file. The conversion to a cut file was pretty rough. I have Pcam and it does the same thing sometimes. Tweaked a few things. It is a not a cut file now but the original cut file is with it . You can convert it the way you want. It is much smoother now.
Hi Guys
Actual the original file was just the locomotive and the tracts. I added the frame, smoke and enlarged the tracks and had to extended them to the frame. I then inserted my nephew name in the side of the locomotive. I had to add the smoke to tie the locomotive to the frame for stability.
Oh by the way I had no trouble cutting out the PCM file that I modified and posted in this post at the top.
Rod in AZ
Rod in AZ
Rod S in AZ
