Another weld jig
- Scratch
Another weld jig
Finally got some time to weld one of these suckers up. I know there are a few different designs of these on here, so I thought I'd throw in the design I like best, maybe someone else will like it. It's super simple and you all can probably draw it up yourself, but I thought I'd share it anyways because sharing is caring right?
I didn't want the holes in it since I figure I'd be clamping it to the table anyways. I did want to be able to fit a vice grip in there... hence the slots. It's 1/4"x4"x12"x12", and the center "web" is in the center of the jig, not flush on the flat edge like some.
Enjoy!
(There are two of the center pieces in the drawing because waste is bad)
Enjoy!
Re: Another weld jig
Pretty sweet Scratch. Sharing is caring Thank you!
- otisa2007
nice thankyou
Nice, thanks for sharing. Have you considered using notches or cutting the corner off so you access inside corner for welding?
Thanks for sharing.
Unfortunately my Qcad won't let me work with it.
thanks a lot, looks like another useful tool.
A very useful share. Thanks
Thanks for sharing!!
Thanks for sharing
- SlagBandit
Good idea! Thank you !
Torchmate 4x4 Growth Series
Hypertherm Powermax 45
Torchmate 1 5x10
Hypertherm Powermax 85
Miller 225 MIG
Miller 210 Syncrowave TIG
Torchmate 1 5x10
Miller 225 MIG
Another to drag up from the depths.
Thank you for the share
thanks
Thanks looks great!
- jmersereau
This will come in handy and save me some $$$'s, thanks.
PrimeWeld CUT60
Langmuir CrossFire Pro
- david jordan
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Can not have enough weld jigs. Great idea, Thank you.
Thanks for sharing
Great Share. Thank you!
That's a great design! And a very handy tool to have for quick setups.
Thank you
