I drew this file with single line font and everything looks good in sheetcam but mach doesnt like it. Suggestions?
Font clean up
Font clean up
- Larry83301
Re: Font clean up
If you zoom in on your font line you will see the problem.wickedinhere wrote:I drew this file with single line font and everything looks good in sheetcam but mach doesnt like it. Suggestions?
Re: Font clean up
Oh joy Thanks
Re: Font clean up
Try this one. I got rid of the lines that didnt match up. There are still lies that overlap right on top of each other but sheetcam should remove duplicate vectors for you. I connected the "b" so it will be one cut not two. there is still the issue of the lowercase "r" having the loop in it. not sure what you wanted to do about that.
