Fajita cooker flat grill
- otisa2007
I haven't shared in quite a while most of my recent work has been using purchased / copywrited files but here's a fajita cooker I drew up and seems to work pretty good the legs are made from 1 1/2 square tubing 36" long it is a plasma cam files so mabey someone can convert it to dxf for others to use
Re: Fajita cooker flat grill
Here it is in .dxf
- steel 35
That looks really good
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
- otisa2007
thankyou mdwalker for the conversion i need to upgrade to the advanced design edge so i can export dxf files
- lazybear
When is lunch? I'll be right over! Looks awesome (the food and the grill!)
Cool little cooker!!!!!!!!!!!!!!!!!
Thanks for sharing
Thanks for sharing
- Zippo
Thanks for posting...
Thanks great share!
cool file
thanks for the cooker and the conversion!
Man that is awesome! I cut one out and having the my boys in class assemble it. Only have one question---What is the 4 little straight pieces used for?
We haven't come up with a good place to put them yet! haha
Thanks again for the design, can't wait to cook on it!
Randy Dobbins
Welding Teacher Humble ISD
I believe the straight pieces/slats go under the charcoal tray.agteacher wrote:Only have one question---What is the 4 little straight pieces used for?
Looks cool
Very popular item otisa. Downloaded 188 times in three weeks.
Thanks for sharing!!!!!!!!!!!!!!!!!!!!!!!!!!!
- otisa2007
The flat pieces weld to the fire pan 2 on the side laying flat to hold it up and the other two go on the bottom to keep it from sliding around on the support pieces that way the pan can be pulled out for filling with charcoal and cleaning im glad everyone likes it and i'm working on modifications to put a gas burner in it ill share that when i get it working
otisa2007 wrote:The flat pieces weld to the fire pan 2 on the side laying flat to hold it up and the other two go on the bottom to keep it from sliding around on the support pieces that way the pan can be pulled out for filling with charcoal and cleaning im glad everyone likes it and i'm working on modifications to put a gas burner in it ill share that when i get it working
One of my boys mentioned about putting a gas burner inside it. That will be interesting for sure!
Thanks again!
Randy Dobbins
Very nice file. Thanks so much!
here is our take on the grill, made a couple changes. What I don't think shows up in the pics is that we added a handle to the charcoal tray and added a couple "shelves" so the tray could be moved closer or further to the cooking surface. Thanks so much for the file, this was fun!
Here's one that shows the handle on the tray a little clearer...
- SegoMan DeSigns
Great coordination with my neighbor (He's got a grilling project underway) I can both see and smell the food on this project..
- otisa2007
Great job on the modifications glad the file is being put to use
- ETCWeld
thanks for sharing and i really like the shelving mods DJC, but what are the horse shoes for?
If your grilling you need a drink holder or 2
- Ironken
Idiot here.....I never learned how to create cuts with compound angles (if that's the correct tem). What's vexing me on this project is how you calculated the sides of the cooking surface and made them meet where you wanted? I would like to make a griddle for our grill with angled sides like the fajita cooker and would really like to learn how to create that geometry. Anybody have any suggestions?
What type of metal is everyone using?
